BC vrs HSD coilovers??
Postby Twincam.22 » Fri Nov 21, 2014 10:29 pm
Any advice on which is best? BC certainly have good name but HSD appear to be good and are bit cheaper too...anyone have experience of both?
Twincam.22
Re: BC vrs HSD coilovers??
Postby klue » Sat Nov 22, 2014 3:03 pm
Twincam.22 wrote:Any advice on which is best? BC certainly have good name but HSD appear to be good and are bit cheaper too...anyone have experience of both?
HSD makes a good coilover very comparable to BC.
BC has more options, and no other company that I know of uses the inverted shock
Postby underscore » Sun Nov 23, 2014 1:48 am
I like my BC's, but the damper they chose for the rears seems a bit short IMO, so my RAM types have the adjustment knobs sitting quite high up (hard to reach).
Postby Twincam.22 » Thu Nov 27, 2014 8:47 am
I went with BC's as just didn't have enough experience with HSD's. Hopefully will be happy with them....
anyone know if i'll need to change any other suspension links when i drop the car to stop inside tyre wear??
Twincam.22
Postby Twincam.22 » Tue Jan 06, 2015 9:09 pm
Anyone have BC's on their GT4 that can shed some advice please?
Twincam.22
Postby klue » Tue Jan 06, 2015 11:05 pm
inside tire wear? as in Camber wear?
did you purchase though me?
Postby underscore » Wed Jan 07, 2015 6:42 pm
Why would you have inside tire wear?
Postby CMS-GT4 » Wed Jan 07, 2015 6:44 pm
Maybe on the rear? Since when you lower the car you gain a lot more camber in the rear.
Postby Twincam.22 » Wed Jan 07, 2015 8:53 pm
No I'm in Ireland lads bought off a friend of mine who sells that stuff. .
I'm worried that when I lower I'll need to adjust suspension in some other way to stop camber wear. The front coilovers have adjustment on the top for camber but rears don't. .
Twincam.22
Postby underscore » Wed Jan 07, 2015 10:45 pm
I wouldn't worry about it, I got an alignment after mine were installed and they didn't have any problems getting it to spec. Also I'm pretty sure toe wears out tires more than camber does.
Postby klue » Thu Jan 08, 2015 2:21 am
Even when the rear lowers the camber is probably not more than -1.5 normal amount for a good street tire
