Wheel bearing questions
Postby UtahSleeper » Mon Dec 08, 2014 6:31 pm
UtahSleeper
Re: Wheel bearing questions
Postby CSAlltrac » Mon Dec 08, 2014 8:48 pm
The hubs and wheel bearings wont effect the ABS or Non-ABS factor. As far as the bearings I would go with a high quality item. The parts are not serviced a lot and the job isnt the easiest so buying something that lasts and is high quality may be costly but very much worth it in the long run. NSK brand bearings are a good choice.
Postby yyonline » Tue Dec 09, 2014 12:39 am
The factory wheel bearings are NSK Japan. Toyota part number is 90369-38003-77. They are pricey but will probably be the highest quality item.
Aftermarket NSK is USA-made, and should still be a decent quality part at a fraction of the price. NSK part number is 38bwd15 and I've ordered those from partsgeek.com before:
http://www.partsgeek.com/ss/?i=1&ssq=W0 ... &x=24&y=15
The Toyota catalog is showing different part numbers for ABS and non-ABS hubs. I've never worked on a ST165, so I can't say what the difference might be.
yyonline
Postby yyonline » Tue Dec 09, 2014 12:41 am
You should also replace the axle hub rubber seals while you have it apart. The hubs can be reused unless they're damaged. You'll need a press and a bearing separator to remove the wheel bearing inner race from the hub shaft.
yyonline
Postby aus jd 2703 » Tue Dec 09, 2014 1:24 am
I work for a bearing distributor in Australia and Toyota use koyo and NSK for their wheel bearings, mostly Koyo as it is owned by a company that also has a share in Toyota, so you will get the exact same bearing as Toyota would use for half the price....
there is no black magic with bearings all the top brands are on par, so it comes down to installation and sealing.
fyi im running koyo atm no issue.
aus jd 2703
Postby smog7 » Tue Dec 09, 2014 4:13 am
yyonline wrote:The factory wheel bearings are NSK Japan. Toyota part number is 90369-38003-77. They are pricey but will probably be the highest quality item.
Part number above for st185 abs? Trying to figure out which to buy, want to have some extras just in case.
-omar
rally tarmac 1990 st185
smog7
Postby UtahSleeper » Tue Dec 09, 2014 4:45 am
Didn't think the rav4 would use the same bearings.
UtahSleeper
Postby UtahSleeper » Thu Dec 18, 2014 6:19 pm
So, is this all I need to replace the front seals and bearings?
2x https://www.rockauto.com/catalog/moreinfo.php?pk=1117003&cc=1273991
(https://www.rockauto.com/catalog/x,carcode,1273991,parttype,1672)
2x https://www.rockauto.com/catalog/x,carcode,1273991,parttype,1860
I assume just ordering 2 kits that have the inner, outer and retainer.
Also wondering if I could use these hubs potentially. Not concerned with ABS functionality as that went out the window with the st215 ECU.
http://www.ebay.com/itm/Front-Wheel-Hub-Bearing-Repair-Kit-Pair-Set-for-Toyota-Celica-Camry-/370944194025?pt=Motors_Car_Truck_Parts_Accessories&fits=Year%3A1988%7CModel%3ACelica&hash=item565dff35e9&vxp=mtr
or
http://www.ebay.com/itm/WD-Express-397-51045-630-Front-Hub-/381056241681?pt=Motors_Car_Truck_Parts_Accessories&fits=Year%3A1988%7CModel%3ACelica&hash=item58b8b8d011&vxp=mtr
(I am just assuming my hubs are toast) And I assume I would just toss the bearings that come with this?
One hub specifies alltrac, while the other says celica and camry. Not sure if they are different.
UtahSleeper
Postby mkernz22 » Thu Dec 18, 2014 7:47 pm
The ABS system has nothing to do with the engine ECU. The entire ABS module and ECU is behind the rear seat in the ST165. If you didn't touch it, then you should still have it there.
mkernz22
1995 Toyota Celica
Postby UtahSleeper » Thu Dec 18, 2014 8:02 pm
mkernz22 wrote:The ABS system has nothing to do with the engine ECU. The entire ABS module and ECU is behind the rear seat in the ST165. If you didn't touch it, then you should still have it there.
Meant more that I thought the ECU tied into it in some way for speed data, rpm or something. Currently my ABS light is on and I don't recall it being on before the motor swap.
I am not really concerned with keeping it functional, so hoping I can use cheaper hubs if the ABS ring is the only difference.
UtahSleeper
Postby mkernz22 » Thu Dec 18, 2014 8:49 pm
They're separate units, the speedometer is in the transmission for the engine ECU and that gives the signal for the speedometer. The ABS speed sensors are only for the ABS module for when you brake. If it senses different wheels speeds under braking then it engages the ABS to pulse the brakes in order to gain some sort of traction again so you aren't just skidding.
However, you should be fine with the different hubs or bearings, only the knuckles are different between ABS and non-ABS. That's as much as I know for the fronts, I still need to look into how the rears are, but I'd bet they're fairly similar.
mkernz22
1995 Toyota Celica
Postby UtahSleeper » Fri Jan 09, 2015 3:25 pm
Well, the hubs are atleast slightly different since the have the teeth for the ABS sensor to read. I may just try and buy a standard hub if mine is toast. At most, I waste a few bucks.
UtahSleeper
Postby CSAlltrac » Fri Jan 09, 2015 7:30 pm
ABS Teeth/ring is mounted on the CV
Postby UtahSleeper » Fri Jan 09, 2015 7:34 pm
CSAlltrac wrote:ABS Teeth/ring is mounted on the CV
Not on the front. In my 165, the teeth are on the hub. No teeth on my front CV axle. Unless I am looking at mine wrong.
UtahSleeper
Postby smog7 » Sun Mar 15, 2015 4:22 am
Same with mine.
Can anyone answer my question from above?
-omar
smog7
