Mario's nylon bushings.... Any Trouble?
Postby camry90 » Mon Jul 13, 2015 3:59 am
I have installed mario's nylon rear subframe and diff carrier bushings on my st185.
I have noticed that the stock exhaust would rub on the subframe. It would create intense vibrations at higher than 4k rpm.
And does it also change the driveline angle? How can i adjust the pitch on the rear diff?
camry90
