ST165 Bushings/Suspension parts and where to buy
Postby UtahSleeper » Sun Aug 16, 2015 3:50 am
So, just recently got my alltrac on the road to flush out other things I need.
Currently I here clunking noises from 2 to 3 of the wheels when any bump is hit. I am assuming that its control arm bushings and maybe sway bar. I would like to just go through and replace alot of the probably worn items there. The question is what and where.
I checked rock auto and it seems that to address anything with control arms, you buy a new control arm. Is that the case? Or are there simple urethance replacement options?
And where do you guys buy your bushings/etc for your alltrac?
UtahSleeper
Re: ST165 Bushings/Suspension parts and where to buy
Postby Awesome-Trac » Sun Aug 16, 2015 5:02 am
I need to know as well!!!
•Daniel
Awesome-Trac
Postby zaluss » Sun Aug 16, 2015 6:05 am
http://www.xiiimotorsports.com/
Hit up Klue and he will set you up with all the bushings you need as well as endlinks.
zaluss
Postby UtahSleeper » Tue Aug 18, 2015 3:16 am
I will have to remember that for later.
I looked under the car today and those bushings seem fine for now(sticking with what is actually broken for now). But I did find my passenger front sway bar bushing is toast. Where do I find those, or what size do most people get? Klue doesn't list it for the celica and neither does rockauto.
UtahSleeper
Postby lumbercis » Tue Aug 18, 2015 4:26 pm
Swaybar bushings you can get from Toyota directly. If you want OEM bushings for the control arms you're correct that you have to buy a new control arm. There are a few aftermarket options of you're okay with urethane. They might cause increased NVH and harshness depending on your overall setup.
Caldina powered...
lumbercis
Postby UtahSleeper » Wed Aug 19, 2015 2:19 pm
Well, I ordered some sway bar bushings just cause I wanted urethane.
I measured 26mm for the front and 17mm for the rear. Does this seem about right? I tried to look it up, but my searches pulled up varying results.
UtahSleeper
Postby Awesome-Trac » Thu Aug 20, 2015 4:00 am
UtahSleeper wrote:Well, I ordered some sway bar bushings just cause I wanted urethane.
Where did you order the sway bar bushings from if you don't mind me asking
•Daniel
Awesome-Trac
Postby UtahSleeper » Thu Aug 20, 2015 4:04 am
Amazon
UtahSleeper
Postby Awesome-Trac » Thu Aug 20, 2015 4:07 am
UtahSleeper wrote:Amazon
Brand name?
•Daniel
Awesome-Trac
Postby UtahSleeper » Thu Aug 20, 2015 4:26 am
UtahSleeper
Postby 3SDNA » Thu Aug 20, 2015 5:49 am
I was going to order the SuperPro bushings from these guys. Has anyone ordered anything from here before?
http://jayracing.com/index.php?keyword= ... gkket8fqb7
3SDNA
Postby klue » Fri Aug 21, 2015 6:32 pm
Hey guys, I've got all the bushings available in poly. Just let me know what you want. They are not listed on my website
Postby UtahSleeper » Fri Aug 21, 2015 7:07 pm
klue wrote:Hey guys, I've got all the bushings available in poly. Just let me know what you want. They are not listed on my website
Well, I was not aware of that. I did check your site first before ordering.
UtahSleeper
Users browsing this forum: Google [Bot] and 3 guests
