Rear bushings help.
Rear bushings help.
Postby Toyotaguy » Fri Aug 28, 2015 11:17 am
Does anyone know of anywhere that I can get the bushings for the rear lateral link on an 88 alltrac? I know the bushing is pressed into the rear knuckles. Any suggestions or link are greatly appreciated.
Toyotaguy
Re: Rear bushings help.
Postby ___Scott___ » Fri Aug 28, 2015 12:20 pm
Scott
Colorado Springs, CO - USA
SONY
Opera - The better browser
___Scott___
Postby Toyotaguy » Fri Aug 28, 2015 12:46 pm
Have you done this yourself. Just wondering cause my parts guy says the part number doesn't link to the Alltracs just supras and Camrys.
Toyotaguy
Postby 88st165 » Fri Aug 28, 2015 3:07 pm
I've done the bushing replacement with the hub carrier still on the car. It wasn't too difficult but people have reported that they broke the eyelet in some extreme cases. Just be mindful of the pressure you are putting on the carrier if you use a 3 jaw puller. If it's stubborn you might need to use some spray, heat, etc.
Black st165 - gone
2011 FA5 - Family Truckster
88st165
Images: 2
Postby Toyotaguy » Fri Aug 28, 2015 3:13 pm
Ok I can get that done at work. I ordered the Febest Tab-002Z hoping it works well for a stock replacement.
Toyotaguy
