St205 Rear Brake Swap St184 bolt on?
Postby plourdem14 » Mon Sep 07, 2015 9:57 pm
Hey guys I have a set of st205 rears and I assumed that they would be a bolt on mod for my st184? Upon installing them they seemed pretty tight. Meaning it was really hard to turn the wheel freely. I tried backing out of my garage and it felt like the e brake was on. Also we can rule out the ebrake because the rotors would spin freely until I installed the calipers. I'm fairly certain I installed the brakes correctly including the sheet metal centering ring. I got my brother to send me a picture of the rear end on his 185 and sure enough the rear hubs do not look identical.
TLDR
Has anyone swapped st205 rears on to a 184 or knows what it takes to do so? I spaced the calipers with two washers per bolt just out of curiosity and they seemed to fit perfectly. So if anyone has specs on how many mm I need to space the calipers that would be appreciated. If I can get numbers hopefully I will be able to get some spacers machined.
Thanks for the help
1990 GTS swapped 3s-gte RC
plourdem14
Re: St205 Rear Brake Swap St184 bolt on?
Postby DeeCee » Wed Sep 09, 2015 1:35 am
I didn't space the calipers for my st205 on st185 rear hub carriers. In fact, I've never heard of anyone having to space the rear st205 caliper when applying to the st185, so I'm not sure why you would need to for a st184. Pictures would help.
Muerz wrote a quick and simple piece on the rear caliper installation
http://turbocelica.nl/howto-st205rearbrakes.htm
Sticky brakes could be the result of you needing to adjust the handbrake pads properly.
Also, CelicaTech.com would probably give you more feedback as this is predominantly an all-trac forum
DeeCee
Postby underscore » Wed Sep 09, 2015 4:28 am
185 and 184 rear brakes are different, and the hubs are completely different given that one has an axle going through it and the other doesn't. You'll need to put the rotor and caliper on (no pads), measure the clearances on each side and sort out spacers of some sort to even things out.
Postby plourdem14 » Wed Sep 09, 2015 3:49 pm
DeeCee wrote:I didn't space the calipers for my st205 on st185 rear hub carriers. In fact, I've never heard of anyone having to space the rear st205 caliper when applying to the st185, so I'm not sure why you would need to for a st184. Pictures would help.
Thanks yeah I find it really weird that there would be a difference from a184 to 185... I'm fairly confident I'm installing them right and the rotor didn't seem warped. Anyways I'll put it out on Celicatech, I just didn't know if anyone stills goes on there.
Also thanks for the tip underscore that sounds like a practical way to figure things out.
plourdem14
Postby fussellbug » Thu Sep 10, 2015 8:37 pm
I know the ST185 brakes bolted directly onto my ST184, but the caliper brackets are longer on the AllTrac to accomodate the larger rotor. If you are using the ST184 caliper brackets, the caliper may sit too close to the rotor causing contact. You can get the ST185 caliper brackets at AutoZone or Advance Auto Parts, so I would pull one of yours and go in to see the difference. Advance lists the ST185 bracket as Wearever Part No. 14-1314.
I can't guarantee this will fix it, but I think the bracket is your issue.
fussellbug
Images: 36
Postby plourdem14 » Fri Sep 11, 2015 12:49 am
That sounds like the solution... I'll look into it, thanks a lot .
plourdem14
