More wheel bearing questions
Postby Toyotaguy » Thu Oct 22, 2015 11:16 am
Ok just a few quick questions on the st165 wheel bearings. Are the front and rear bearings the same size? Any problems people may have run into while doing there's and if any one has use aftermarket bearing how have those held up. All opinions welcome
Toyotaguy
Re: More wheel bearing questions
Postby zaluss » Thu Oct 22, 2015 12:20 pm
Toyotaguy wrote:Ok just a few quick questions on the st165 wheel bearings. Are the front and rear bearings the same size? Any problems people may have run into while doing there's and if any one has use aftermarket bearing how have those held up. All opinions welcome
IIRC the front and rear are the same size.
My recommendation is Timken. I used them on my ST165 with great results. http://www.rockauto.com/catalog/moreinf ... 477&jpid=4
zaluss
Postby yyonline » Fri Oct 23, 2015 7:37 am
Front and rear wheel bearings are the same for the AWD Celicas. The Toyota part number is 90369-38003-77.
I used aftermarket NSK front wheel bearing in my 93 Celica ST: http://www.amazon.com/NSK-W0133-1628445 ... B008S227EY The same bearing fits both the front and the rear of the ST165 and ST185. It's holding up well to date. NSK is one of the suppliers Toyota uses for the wheel bearing.
yyonline
