st165 soft brakes
st165 soft brakes
Postby vishal25pm » Thu Feb 11, 2016 3:32 pm
any one else feel like the st165 has a really soft pedal? i just got mine running for the first time and the pedal just feels so soft.. i changed the booster, master and check valve to the intake. and bled it all, but i just doesnt feel like other toyotas ive had like the mk1 and mk2 mr2s, or even my old 90 tacoma.. is there something im missing or should i just get used to it?
vishal25pm
Re: st165 soft brakes
Postby monkey8oi » Thu Feb 11, 2016 5:27 pm
change out the brake lines to some steel braided ones..
monkey8oi
Postby vishal25pm » Fri Feb 12, 2016 10:29 am
oo i will order some of those, does it make such a great difference?
vishal25pm
Postby bmt » Sat Feb 13, 2016 8:15 am
Yep if they are old they bulge under pressure thus giving you a soft pedal. New fluid?
bmt
Postby vishal25pm » Tue Feb 16, 2016 2:45 pm
They are definitely old, im pretty sure everything on this car is original from 1988. lol. i have a set ordered, should be on by next weekend =)
vishal25pm
Postby 88gt4DE » Tue Mar 22, 2016 1:35 pm
Change front brakes to 185 brakes .... makes a world of difference ....
Postby Camshaft1987 » Tue Mar 22, 2016 3:04 pm
My 88 alltrac brakes feel pretty soft as well but consistent. Can i ask where you found those braided lines. Is it all four as a package. anyway thanks
Camshaft1987
Postby 88gt4DE » Tue Mar 22, 2016 3:10 pm
I did do the stainless lines also but only cause I needed new brake lines. Got them on Ebay ... The bigger part of the feel will come front larger front brakes ... 185 stuff is all a bolt on , just can't run the 14 inch wheels anymore ...
Postby Tecker185 » Tue Mar 22, 2016 4:34 pm
Make sure the calipers are installed correctly with the bleeders at the top. Ive done it and you cant get the air out.
89 ST165
89 SV25
86 AW11 2zzge swapped
86 AE86 1uz swap
89 AE95 sedan
89 AW11 Supercharged
17 4runner TRD Off Road
Tecker185
