ST165 Spring Rates...
Postby JRWperformance » Fri Jan 27, 2017 6:02 pm
I'm building my own coil overs for my 88 AllTrac. I'm using KYB AGX front inserts on all 4 corners. I plan to run lower dampening in the winter and stiffer in the summer. I also want summer springs and Winter springs.. I'll be using some universal sleeves from summit racing. I might use 8 to 10 inch long sleeves for crazy amounts of adjustment.
I live in Anchorage Alaska and our road maintenance budget has been slashed over the years due to the lack of snow for the last few winters. So when we got dumped on the last couple weeks, the roads became rediculous. Many cars stuck on the side of the road in the 4 or 5 foot tall snow berms. You would think that snow being soft and fluffy would be smooth to drive over on the roads...Nope. Damn roads turn into trench warfare...
I want to build a rally style suspension with some actual travel to soak this crap up. Anyone else out there on the forums build a rally Celica? What are the dimensions of your springs? I know the factory rally cars were getting close to 8 inches of travel. But I'm sure that was all custom work. What kind of travel does a stock st165 have?
88 Celica Alltrac
78 Honda GL1000
04 Volvo S60R (Now Dead)
91 VW Jetta Turbo Diesel
JRWperformance
Re: ST165 Spring Rates...
Postby JRWperformance » Sun Apr 09, 2017 9:52 pm
I went with 350lb front and 300lb rear. All 4 are 12 inches long. These seem to do the trick. Lots of travel, yet still sporty.
88 Celica Alltrac
78 Honda GL1000
JRWperformance
