Lower Ball Joint Clearance Problem on ST165 (ST205 Brakes)
Postby Celica Turbo » Mon Apr 10, 2017 8:01 am
Hello
I installed long time ago the ST205 front brakes on my ST165 without Brake Caliper Brakets. The Brake Discs are machined down to 302 mm in diameter. I installed a 4mm Spacer between Hub and Brake disc, and on the caliper we machined down 4mm to. Brake Disc is 100% in the middle.
But the Brake Discs touch the Lower Ball Joints.
Exists there any other options to get more clearance between Ball Joint and Brake Disc?
I think, others has/had the same problems with the ST205 Discs with Diamater ~300 mm.
Thanks for your help.
Celica Turbo
Celica Turbo
Re: Lower Ball Joint Clearance Problem on ST165 (ST205 Brake
Postby zaluss » Mon Apr 10, 2017 3:10 pm
Celica Turbo wrote:Hello
Celica Turbo
Looking at this thread it seems that redrilling is300 or is200 discs will work.
viewtopic.php?f=8&t=20216&start=195
Let me know if that works for you as I'm also curious since the last person on the thread seems to have done it.
freddie wrote:My 165 has 205 calipers and discs on the rear. Front 205 Calipers with Lexus IS200 Discs. 165 Master cylinder and booster.
Technical help can be found on this site and I also had help thanks to fcZach.
Master Cylinder - pedal travels a bit more. (but I will be changing to a 205 master cylinder and booster soon)
Wheels - currently running 16x7.5 inch 3 piece with 30 offset. Yes on rear the calipers hit the inside of the wheel center,
so I run 25mm thick spacers. Clearance of rim to caliper (outwards) is about 15mm.
zaluss
Postby Celica Turbo » Tue Apr 11, 2017 4:56 am
Hello
Thanks for your response.
My Problem is, that other Brake Discs from the IS200 or the IMPREZA are not be a option, because i allready installed some expensive front and rear brake Discs from ENDLESS Japan. And the Brake Discs are no longer available. I need to replace the rears too, if i install new ones on the front axle. The ENDLESS Brake Discs costed years ago about 1500 USD for front and rear.
Is there no one who makes aftermarked Ball Joints? I think i had seen someone in this Forum with Spherical Custom Ball Joints, but i can't find it anymore.
Or should i install a bigger Spacer between Brake Disc and Hub? 8mm?
But it fits al perfect now with the 4mm Spacer.
Any other ideas?
Celica Turbo
Celica Turbo
Postby underscore » Tue Apr 11, 2017 5:55 am
You could try shaving down the joint a bit. Have they only recently started touching or have they always done this?
Postby Celica Turbo » Tue Apr 11, 2017 10:06 am
underscore wrote:You could try shaving down the joint a bit. Have they only recently started touching or have they always done this?
Hello
Shave down the Ball Joint is a option for sure.
The Brake discs touching the Ball Joint since i installed the ST205 Brake.
Celica Turbo
Celica Turbo
