ST165 - What strut inserts have been tried?
Postby UtahSleeper » Wed May 03, 2017 5:28 pm
So, I have a spare set of struts I am planning on converting to coilovers and curious what inserts people have used.
I know AGX is pretty common, but any others? Reviews? Anyone use adjustable inserts?
UtahSleeper
Re: ST165 - What strut inserts have been tried?
Postby Mr Alltrac » Wed May 03, 2017 7:46 pm
I know Koni inserts are pretty common and I'm pretty sure there adjustable. I know they are on the 185 platform.
Mr Alltrac
Postby Redrkt01 » Thu May 04, 2017 7:55 pm
^They're adjustable. Good luck finding them though....
1989 ST162
1988 ST165 Black
1988 ST165 Red Parts Car
Redrkt01
Postby JRWperformance » Fri May 19, 2017 5:29 am
My KYB AGXs are good. Comfortable on #1 and really stiff on #4. They are simple and effective.
88 Celica Alltrac
78 Honda GL1000
04 Volvo S60R (Now Dead)
91 VW Jetta Turbo Diesel
JRWperformance
Postby ChrisD » Tue May 30, 2017 3:54 pm
Redrkt01 wrote:^They're adjustable. Good luck finding them though....
Twos R Us can generally get them for good prices.
I am running Koni yellows. They are great. Have dampened very rigid springs quite well for me. Make for a very comfortable ride that is track capable. Highly recommend. I previously ran KYB GR2's and also the AGX's. GR2 is an OEM replacement, AGX is a good budget option but doesn't really compete with the Koni's. If you have the money, I'd go Koni.
Here is what I'm now running:
Front: 8610-1318 (Subaru Legacy 94-96 front)
Rear: 8641-1211 (ST185 front fitment)
The rears have a threaded end which you throw a bolt on underneath the housing to secure.
1988 ST165
1994 ST205 WRC
ChrisD
Postby zaluss » Tue May 30, 2017 4:04 pm
Front: 8641-1211 (ST185 front fitment)
Rear: 8610-1318 (Subaru Legacy 94-96 front)
The rears have a threaded stud which you throw a nut on underneath the housing to secure.
This is good info for when I do the rear conversion. Did you just use doner front strusts to do the threaded top?
zaluss
Postby ChrisD » Tue May 30, 2017 5:01 pm
I got that mixed up. I'll edit my post. I put the 185 fronts on my rear, and the subie ones on the front as they were for a slightly heavier car. The subie struts did not require the threaded top, as they have a bolt in the bottom to hold them in. but yes I used some old fronts to weld on the threaded top to the rear, which now houses koni yellows designed for 185 fronts. This reminds me of why I got mixed up. haha!
1988 ST165
1994 ST205 WRC
ChrisD
Postby zaluss » Tue May 30, 2017 7:25 pm
Thanks Chris!
So it looks like roughly $700 for the Koni's + $500 for the GC + welding/painting/prep. $1200~ isn't too bad all things considered.
I wish I went this route instead of coilovers. I'm probably going to go this route anyway :D
zaluss
Postby UtahSleeper » Wed May 31, 2017 8:15 pm
Thanks for the reply!! This is the info I need. I may aim for the yellows so I can just cut the tops and secure to the bottom.
UtahSleeper
Users browsing this forum: fussellbug, Google Adsense [Bot] and 3 guests
