Rear Swaybar Endlinks Upgrade?
Postby etantshi » Sat Jul 08, 2006 5:51 pm
So are the rears still the only ones available?
André B.
1991 ST185 (down but not out)
1996 RZN140 (the daily)
etantshi
Postby omgitsroy326 » Mon Aug 14, 2006 6:51 pm
etantshi wrote:So are the rears still the only ones available?
yes
omgitsroy326
Postby SeanGTS » Mon Aug 14, 2006 7:01 pm
I'm running the ones from Two's R us as well, working fantastically thus far!
Thanks Mr. Hawkins
Sean
Master Swapper
SeanGTS
Postby David Hawkins » Mon Aug 14, 2006 7:19 pm
If someone's willing to be a guinea pig for the fronts, let me know. You'd have to replace the pair to avoid preloading the bar, but I don't see any reason why a link that's about 1/4" longer wouldn't work.
I'll have to order the male parts in to make them...would take about a week after ordering.
717-638-1108.
David Hawkins
93 ST185 - 93 MR2 Turbo - 00 MR2 Spyder 2ZZ/6spd
http://twosrus.com
http://clubmr2.com
David Hawkins
Postby smog7 » Tue Jun 12, 2007 8:56 pm
bump, has anyone had any experience with the fronts?
-omar
rally tarmac 1990 st185
smog7
Postby David Hawkins » Tue Jun 12, 2007 9:56 pm
I've sold about 25 sets of fronts, so there must be some people who can post up their opinions...
David Hawkins
http://twosrus.com
http://clubmr2.com
David Hawkins
Postby Conan » Thu Aug 23, 2007 10:21 am
Is it normal that RB links are under stress in the joints when installed as they don't flex as easily as the stock joints? :shrug: The mounting surfaces of the strut housing and the sway bar are not parallel, so some force needs to be applied in order to fit the links. Will urethane hold the load reliably? :roll:
Conan
Postby saki10man » Tue Oct 30, 2007 1:26 am
Are the RB endlinks that can be used as an upgrade for the 185 be used on the 165? :shrug: Would like to order a set but need to for sure.
Thanks
saki10man
Postby Mafix » Mon Dec 17, 2007 11:34 pm
here is what i'm running on.
Postby 88st165 » Tue Dec 18, 2007 4:30 am
ive got speed-source ones along with the w/l sway on my red 165... they seems to be doing a great job...
ive got the rb ones with the w/l sway also for my white 165 but i havent installed them yet...
mafix i was thinking of doing something like that for the front... where did you get the supplies from? McMaster-Carr?
Black st165 - gone
2011 FA5 - Family Truckster
88st165
Images: 2
Postby Mafix » Tue Dec 18, 2007 8:01 pm
yep
Postby 88st165 » Wed Dec 19, 2007 12:45 am
part numbers? i cant seem to find those type of joints on the site, not unless im not looking in the right place... :doh:
Black st165 - gone
88st165
Images: 2
Postby Mafix » Wed Dec 19, 2007 12:51 am
type in joints - hit arrow search
first choice in that side bar for ball joints - click on it
enjoy the searching! just about everything you can imagine.
mine have 4000lb rating and 3/8" holes, which is a touch bigger than stock IIRC.
Postby Andy » Sun Dec 30, 2007 2:34 pm
The 'Ebay" link to the Mercedes rear sway bar links is dead.
Does anyone have the Mercedes part number for these?
Below is a summary of what I have found....
Racingbeat $56 (Adjsutable)
http://www.racingbeat.com/resultset.asp?PartNumber=54200
Twosrus $75 (Adjustable)
http://www.twosrus.com/catalog/product_info.php?cPath=24_79&products_id=254&osCsid=2e37b6344b275529daaa0f7552504c86
Nolathane $74.52 (Non Adjustable)
http://www.gimmecarparts.com.au/search.cfm?SearchCategory=TP825
Pic... http://www.redranger.com.au/images/products/complete-swaybar-links.pdf
935 Motorsports $75 (Adjustable)
http://www.twosrus.com/catalog/product_info.php?products_id=254
Mercedes $32 (Non Adjustable)
? part number
I know the Mercedes ones were $32 back in '05. I've put over 30k miles on a set of them and they're doing just fine. But the ebay link is dead and I can't find the Mercedes part number for them. We need another set for a different Alltrac.
Does anyone know the Mercedes part number?
Thanks,
Andy
Andy
Postby MrDB » Mon Feb 18, 2008 2:14 pm
MrDB
