Rear Swaybar Endlinks Upgrade?
Re: Rear Swaybar Endlinks Upgrade?
Postby Corey » Fri Jul 19, 2013 7:17 pm
Has anyone used the Miata endlinks with the whiteline rear sway bar?
Corey
Images: 50
Postby Meenya » Fri Aug 16, 2013 3:25 pm
Corey Darling wrote:Has anyone used the Miata endlinks with the whiteline rear sway bar?
For soft and med setting it's fine but it might not work for hard setting...links appear to be too long, but I haven't actually tried to set it to hard setting yet..
Mike
93 Turbo 4WD
91 GTFour RC
07 R6
Meenya
Images: 19
Postby mx6er2587 » Fri Aug 16, 2013 4:06 pm
I used to make and sell adjustable stainless steel heim joint endlinks. My links used two female joints so they're too long for the front links on the alltrac but work great on the rear.
I used teflon coated rod ends so no lube needed and no rusting up. I never bothered with heim spacers but you certainly could.
I might still have a few sets kicking around the garage if anyone is interested.
mx6er2587
Postby YerRandO » Sat Aug 17, 2013 4:02 am
I have 949 racing miata endlinks with a whiteline adjustable rear sway bar on stock suspension
-James
YerRandO
Postby Corey » Sun Aug 18, 2013 4:24 pm
The 949 racing endlinks are heim joint right?
I tried the Racing beat poly endlinks - no go. Not even close.
I'm back to using tried and true OEM endlinks with the whiteline sway bar. They still work, even on the hardest setting.
Corey
Images: 50
Postby Domspun » Mon Aug 19, 2013 1:38 am
I've got Mevotech ones on mine. Cheap and same design as the MOOG, no allen key and greasable.
Domspun
Postby Corey » Mon Aug 19, 2013 2:05 am
^ Those look nice, where did you buy them?
Corey
Images: 50
Postby Domspun » Mon Aug 19, 2013 6:31 am
Corey Darling wrote:^ Those look nice, where did you buy them?
http://catalog.supraz2000.com/ but it's not on their website. Part number is MK9545. If I remember correctly, they are almost half the price of the Moog's.
Domspun
Postby 5thgenbliss » Tue Aug 20, 2013 8:10 pm
Gents.
Long time no post for me. I've been interrupted by "life"
Corey, when I put in the Whiteline swaybar a few years back, I used the Racing Beat endlinks as it was an option I read about in posts on here back then. The other option is making your own using McMaster components.
Long story short, in the medium setting, the links work but aren't perfect. On my stock suspension, from time to time the bar binds on the stupid brake line bracket, which isn't a good thing. Looks like it needs to be longer and the Racing Beat links are at its max length already.
Funny that some people were able to make them work without binding issues. I think I will have to do the McMaster route unless mx6er2587 found a set he mentions.
Boosting with the '92 GT4 RC
5thgenbliss
Postby Meenya » Tue Aug 20, 2013 9:03 pm
Twosrus sells them as well they offer 2 options:
Chrome plated or Full SS...you can find it on their website.
Mike
93 Turbo 4WD
91 GTFour RC
07 R6
Meenya
Images: 19
Postby Corey » Tue Aug 20, 2013 10:35 pm
^ I've already tried the twosrus end links, full stainless. They lasted about 10k km here in the dusty, hot/freezing conditions of moose jaw. They might be okay on smooth city roads, otherwise I'd stick to oem or another brand with rubber boots to protect the joints
Corey
Images: 50
Postby klue » Tue Aug 20, 2013 10:54 pm
Corey Darling wrote:^ I've already tried the twosrus end links, full stainless. They lasted about 10k km here in the dusty, hot/freezing conditions of moose jaw. They might be okay on smooth city roads, otherwise I'd stick to oem or another brand with rubber boots to protect the joints
your right, the rod ends are more for track vehicles. For street use I would say go with a polyurethane or OEM booted ball socket style
I've had great success with the whiteline style seen here
http://www.whiteline.com.au/product_detail4.php?part_number=W23180
Plug: your forum vendor, xiiimotorsports is also a authorized dealer for whiteline products :)
Postby Cuttyman9 » Sun Apr 20, 2014 5:04 pm
T3 should have some available soon.
I stopped by and they had the parts they just need to build the part that connects in between.
1992 Celica GT Hatch
1971 Cutlass
1967 Chevelle
1975 Trans Am
1966 C20 Long Bed
1999 F150
Cuttyman9
