...did you have any problems with the backs of your aftermarket rims being flat, and not able to accept the nubs of the stock studs that poke through the spacer. I have the spacers on with the stock rims and that works OK, though there's still a little contact inside the recesses. While test-fitting my TD rims however, there's no recesses and the rim is sitting on the tops of the OEM studs, which I'm assuming is bad. I have some 5mm spacers, but stacking spacers seems equally ghetto. I guess I'll have to choose between new rims or the wider track - not both.
Anyone else have this problem and have to install shorter studs to put on spacers? Maybe having the wheels machined would be easier... I don't know, just frustrated. Rocketeer recommended these exact spacers with the rims and I guess I just assumed it would work.
