The alltrac weight reduction thread
Postby Corey » Sat Dec 15, 2007 6:04 pm
How much does the stock ATA front bumper weigh?
thx
Corey
Images: 50
Postby Sifu » Sat Dec 15, 2007 6:32 pm
??? Stock ata front bumper? The top mount you mean? Close to 5-7 lbs.
BROKEN! BUT NOT BEATEN!
2005 Scion tC FW21
1985 AW11
1987 AW11
Sifu
Postby Corey » Sat Dec 15, 2007 6:38 pm
yeah sry, standard GT4 front bumper? Im going to put my car on a diet.
Corey
Images: 50
Postby Klas » Wed Dec 19, 2007 3:57 am
Here are some st165 weight info.
This are all the weight savings so far, haven´t weigh the stock intercooler vs the fmic, not the stock exhaust sys vs the 3 in no cat system either.
This is what I´ve get rid of:
asfalt soundstopper 7.5kg-16.5lb
vacum stuff 1.5kg-3.3lb
other stuff enginebay 3kg-6.6lb
airmassmeter 2.3kg-5.1lb
brackets 0.4kg-0.9lb
gastank brackets 1.8kg-4lb
towingloops front 1.6kg-3.5lb
idlemotor 0.4kg-0.9lb
hoodlock 0.6kg-1.3lb
intake soundbox 0.9kg-2lb
trunk dampers 0.9kg-2lb
rear wiper 1.4kg-3.1lb
tools 1kg-2.2lb
jack 2kg-4.4lb
2 stock fenders 7.6kg-16.7lb
metal sunroof 4.5kg-10lb
2 stock rearside windows 5.1kg-11.2lb
metal trunklid 10.7kg-23.5lb
metal hood 15.8kg-34.8lb
2 front seats 39.3kg-86.5lb
fueltank 14.5kg-32lb
rear window 9.7kg-21.3lb
total:132.5kg-291.5lb
This is what I´ve put on:
fiberglass sunroof 1.9kg-4.2lb
2 fiberglass fenders 4.4kg-9.7lb
2 rear side poly windows 2.8kg-6.2lb
fiberglass trunklid 3.8kg-8.4lb
fiberglass hood 5.9kg-13lb
2 racing seats 22kg-48.4lb
rear poly window 4.9kg-10.8lb
fuelcell 5kg- 11lb
Total: 50.7kg-111.5lb
I have´t included the deleted spare tire. I saved 1.5kg-3.3lb by swaping the fuel lines with alu tubes and saved 1kg-2.2lb with my new steeringwheel.
My total weight saving is around 84.3kg-185.5lb (so far)
1/4 in 12.577s 176km/h so far
If you can turn, you drive to slow!
Now on youtube!
http://www.youtube.com/watch?v=hSD6LlwS830
Klas
Postby Sifu » Wed Dec 19, 2007 4:08 am
Thanks for the weights. I will add them into the weight thread later...
2005 Scion tC FW21
1985 AW11
1987 AW11
Sifu
Postby Corey » Wed Dec 19, 2007 6:21 am
I just weighed my JDM spare wheel: Came in at 27 pounds according to bathroom scale.
Corey
Images: 50
Postby Gary » Wed Dec 19, 2007 6:58 am
Are you talking about the AFM? :shock:
I weighed mine and it came out only 2.5 lbs.
93 ST185
Gary
Postby Klas » Wed Dec 19, 2007 7:24 am
Yes, It was almost a year ago I did this, I maybe weigh it with my brackets and the strait intake hose? Hard to remember :lol:
Now on youtube!
Klas
Postby timmey » Thu Oct 23, 2008 5:43 am
Corey Darling wrote:I just weighed my JDM spare wheel: Came in at 27 pounds according to bathroom scale.
Yay! I took that out, the jack and the carpet/plastic piece to relocate my battery..lol. I guess thats all I've done.
timmey
Postby concealer404 » Mon Mar 09, 2009 4:33 pm
Anyone know how much the power steering pump weighs?
Cars and stuff.
concealer404
Postby Rpz123isme » Mon Mar 09, 2009 9:27 pm
i regret removing and trashing all of my power steering stuff. the car has a completely different feel. not in a positive way.
Hesperia, CA
Rpz123isme
Postby concealer404 » Tue Mar 10, 2009 1:52 am
Rpz123isme wrote:i regret removing and trashing all of my power steering stuff. the car has a completely different feel. not in a positive way.
Probably true... but that's also something that affects a 2400lb car a lot less than a 3300lb car.
And mine is leaking to the point it borders on ludicrous. And i don't feel like paying to fix it. If done right it should only suck while parking. Even when i was fighting the pump in my old car, it was easily manageable once going faster than 15mph. This car is easily 300lbs lighter, and i won't be fighting the pump. Was more curious about how much it weighs.... i'll find out if nobody has input within a week.
Cars and stuff.
concealer404
Postby JDM GT-Four » Thu Apr 16, 2009 3:53 am
I just weighed the Gt-four(gutted,no back seat's etc) it came in at 2995! not too bad! I believe stock was 3250.
1990 ST-185, narrow body
GT-2871R--no more
GT-3582R--getting installed!!!!
AEM EMS(installed finally!!)
JDM GT-Four
Postby CMS-GT4 » Mon Apr 20, 2009 5:01 pm
When you say gutted, do you mean no dash, or interior plastic, etc...?
Do you have the sunroof, or AC? Power windows? Narrow body or widebody?
Postby lumbercis » Mon Apr 20, 2009 5:36 pm
Not to pick on you or anything, but I don't think that the solution for not having enough money to fix something is to yank the system out. Your car will eventually be a worthless shell if you keep following that line of thinking. If you don't want to pay to fix it, get a set of BGBs and some tools and troubleshoot the problem. You may find out you just need new hoses and not a new pump.
Also, taking out power steering doesn't give you manual steering, it gives you broken power steering. To get the same effect as manual steering, you would need to swap in a manual rack. But that might end up being the same or more money as just fixing the power steering.
EDIT: Just noticed you have a GT. You might want to hunt around the junkyard for a GT with a manual rack and swap it out. Might be the most economical solution.
Caldina powered...
lumbercis
