The alltrac weight reduction thread
Re: The alltrac weight reduction thread
Postby MXP_57 » Mon Sep 20, 2010 6:36 am
I have an st185. i just have the radio and two front speakers. It's still a street car :-D
For the future i plan on fiberglass body work and lighter windows. But i don't know how much i can get down to with the stock body and windows. It's pretty much all stripped...
I will weight the car soon. The car is still in a 1000 pieces. I'm redoing the whole wiring of the car right now...
CEIKA Demo car 1987 ST165 JDM 1000kg/700hp http://ceikaperformance.com
MXP_57
Postby sleeper » Mon Sep 20, 2010 7:23 pm
My guess is that you can get down to about 1250-1240. ( race rdy)
sleeper
Postby MXP_57 » Mon Sep 20, 2010 8:22 pm
What is the stock weight of the early jdm st165?
MXP_57
Postby MXP_57 » Tue Sep 21, 2010 12:11 am
I've calculated that i've lost ~210kg. ~462lbs. :shock: This is pessimistic, there's lots of small stuff i didn't count.
The alltrac specs page says under "GTfour" that the st165 weights 1350kg. Is that with fluids or driver? If it's dry, then my car should weight 1140kg !!
MXP_57
Postby Celi-GT4 » Tue Sep 21, 2010 12:23 am
I had my 185 down to 2840lbs with a roll cage, wet. I have lots of stuff out of her as well. The chromoly cage wieghs about 60lbs.
12.4 @ 115mph Topeka Kansas NA2005
12.2 @ 109mph blew HG Moroso 1/08
Sold out, now on stock 3rd gen
Blitz ecu, dp,exhaust, tien ss, carbon driveshaft,light wheels/brakes,os giken twin plate
Celi-GT4
Postby darthripley » Sat Nov 27, 2010 7:14 pm
Celi-GT4 wrote:How about carbon driveline and lighter wheels? Bumper supports? Stereo? Sytem ten in 185 is heavy. Swap out some glass too. Door and window control motors etc will lighten it IMHO about 15-20lbs, I think you can get to 1150. What do you wiegh now?
C/F driveshaft is 30lbs lighter than stock & helps with rotational mass.
R/C front crash bar is aluminum & much lighter than the steel widebody crash bar.
Someone in the UK makes FRP rear hatch & if you put lexan window in that you could save ~30-40lbs.
ABS weighs a ton & all the related wire/loom that goes to it.
Spal fans weigh a lot less than stock fans + shrouds as well.
I'd personally work on the drivetrain being as light as possible -> wheels, brakes, driveshaft, shimless buckets, flywheel, clutch + getting weight off the front for a more balanced feel.
Good luck with it all :)
87 AW11 MR2 "Super 2" 4AGZE
99 SXV20 Camry "Maul" 5SFE
Female Moderator
darthripley
All Trac Goddess
Postby BNZ » Sat Nov 27, 2010 7:24 pm
Lightened 165 Crash Bar ... not crushproof anymore but much more lighter ! :)
Street ST185
Rally ST165
HillClimb Renault 5 GTE
BNZ
Images: 31
Re:
Postby lumbercis » Sun Nov 28, 2010 3:15 am
concealer404 wrote: .... But that's fine, it's NOT meant to be a daily driver. I don't really care about the resale value, it's a track toy. And from that standpoint, less weight = better. The car has an end goal of under 2400lbs w/ a gen3 swap. :D
Oh, I didn't see you mention before that you were preparing the car for the track. What type of motorsports are you preparing the car for?
RE: darthripley's post, be aware that if you are doing weight reduction for motorsport, some of those reductions will disqualify you from certain classes or else class you up into a class you couldn't hope to be competitive in. Specifically lexan windows are disallowed in all but the most heavily modified classes (think black halfs, tube frames etc.) Some of the others may or may not depending on the specific motorsport/class.
If you are putting lexan into a street car, then also look out for Smokeys as it is illegal to run them in a street car in many states.
J.
Caldina powered...
lumbercis
Postby darthripley » Sun Nov 28, 2010 6:43 am
^ that is correct regarding lexan/polycarbonate in the US, it is not DOT legal & you fail a safety inspection in states that require them.
in some forms of motorsport overseas it is within the rules - it might even be street legal in some countries, but I cannot comment on any of that as I am uncertain etc.
i'm sure the poster asking about weight reduction for track would have a full knowledge of what is legal & what is not in whatever motorsport he is competing in.
honestly there would be no sense in doing tons of weight reduction work to a track specific car & then not be able to compete with it anywhere. :|
Female Moderator
darthripley
All Trac Goddess
Postby Mitsuslider » Sat May 14, 2011 4:54 am
Scaled my st165 at 3484lbs (with me in the drivers seat and completely loaded), with a 51% front and 49% rear weight ratio. Where can I get a fiberglass hood, sunroof, etc. Ive recently removed full ps system, full ac system and brackets, cruise control, and other miscellanious items. not looking for a dramatic drop in weight but id like to get the crossweights and bias as close to perfect as possible.
Mitsuslider: "I broke your candy!"
Mitsuslider
Postby BNZ » Sat May 14, 2011 6:18 am
For the statistics,just scaled the whole sunroof assembly : 14kg
Now is replaced by a 600g aluminum nicely-curved plate
Mitsuslider,i am in the process of making fiberglass doors,hood and hatch for my rally ST165. I have a door almost finished,will post pictures with it finished here : viewtopic.php?f=24&t=28964&start=15
Street ST185
Rally ST165
BNZ
Images: 31
Postby Corey » Tue Jun 28, 2011 2:16 am
Does someone happen to know how much the Rear subframe weighs?
Corey
Images: 50
Postby CMS-GT4 » Tue Oct 14, 2014 6:58 pm
Corey Darling wrote:Does someone happen to know how much the Rear subframe weighs?
I don't have weights at the moment, but I know the cross bar on it is supposed to be lighter for the 205. Once I swap them I'll get some weights.
Postby CMS-GT4 » Tue Nov 25, 2014 11:00 pm
Carbon fiber floor pan.
http://www.lewisrallysport.com/shop-pag ... 05/6988426
EDIT this may be an addition part and not a replacement.
Postby fhalperformance » Tue Apr 14, 2015 2:10 am
2960 lbs according to the corner weight scales at the track. 1993 Alltrac street driven no cutting involved.
No interior save the dash, steering wheel, door panels & factory seats.
No audio system/boxes
No carpeting
No trunk plastics
No rear bumper cover/foam/upper trim piece (below tail lights)
RC conversion with aluminum crash bar
ST205 motor
3 Inch turbo back exhaust
Solid motor mounts
Solid rear diff mounts
No fender liners
WTA intercooler with factory pump
No sway bars, brackets or links
No exhaust heat shields
BC racing coilovers
Volk GT-7s with 215/40r17 kumho ecstas
Aluminum reproduction fuel tank (half tank)
No spoiler pieces
No a/c
No cruise
'93 trac - V6TT project.
'91 trac - 564awhp.
'91 mr2 - parting out.
'04 ducati 999
'04 tacoma TRD - for sale
fhalperformance
