Alltrac Handling FAQ
Postby etantshi » Mon Jul 03, 2006 12:58 am
Any more information on the cusco underbody brace?
André B.
1991 ST185 (down but not out)
1996 RZN140 (the daily)
etantshi
Postby CMS-GT4 » Mon Jul 03, 2006 1:35 am
Basically, the underbrace attempts to stiffen the chassis a bit. The benefits (supposedly) are improved turn-in and a more stable geometry when handling near (or at) the limits.
Noticable improvement in quick steering changes such as when making quick lane changes/slalom (given the tires are sufficient enough to exploit it).
And just a reminder, no matter how good your suspension is, without good tires, it means little.
Postby etantshi » Mon Jul 03, 2006 5:33 pm
No, I meant personal experience. I believe you said you were going to try it out. Sorry for being vague.
André B.
etantshi
Postby exST165 » Thu Jul 06, 2006 12:48 am
CMS-GT4 wrote:Talks about adjusting the caster of the alltrac.
http://alltrac.net/phpBB2/viewtopic.php?p=125852#125852
This link doesn't work for me.
mtbgael, can you provide details on how you sloted the bolt holes to get more camber, or is that pretty much it: remove strut, enlarge hole, replace strut and make sure the bolts are torqued to spec? I've heard of people making their own camber-plates so they can play with camber and caster and I'm just wondering how that compares to making some bigger holes/slots within the ability of the bolts/washers to grip the remaining sheet metal.
TIA,
Thomas
exST165
Postby Gary » Thu Jul 06, 2006 12:56 am
change phpBB2 to phpBB3
93 ST185
Gary
Postby exST165 » Thu Jul 06, 2006 11:20 pm
Thanks!
exST165
Postby CMS-GT4 » Fri Jul 14, 2006 4:04 pm
Celica Tech thread on weight reduction.
http://www.celicatech.com/forums/showth ... post205044
A gts owner got his car down to 2395 from 2980lbs. He removed interior, used lighter seats and removed uneccesary items from the engine bay.
Still has a moon roof and factory glass.
I think an alltrac could get down to the 2700lb range with the same methods.
Plus you can save 35lbs off the roof ~25lbs with a cf hood, and some more weight with a cf hatch.
A fuel cell, lighter suspension parts, wheels and a few other items plus the ones I listed, I bet an alltrac could see ~2500-2600lbs.
Should make a nice track car around that weight.
Postby CMS-GT4 » Thu Aug 10, 2006 5:51 pm
Weight of items in the alltrac. So you know the saving that can be obtained by removing x item.
http://alltrac.net/phpBB2/viewtopic.php ... 4d03231db8
Postby CMS-GT4 » Wed Sep 13, 2006 9:51 pm
Thread and turning the cushy luxury of the alltrac into better feedback and performance.
http://www.alltrac.net/phpBB2/viewtopic ... 990#145990
Postby CMS-GT4 » Fri Feb 02, 2007 1:17 am
Postby smog7 » Fri Feb 02, 2007 5:50 pm
can someone make this a sticky??????????
-omar
rally tarmac 1990 st185
smog7
Postby CMS-GT4 » Fri Feb 16, 2007 5:10 pm
Postby Denver_whiteST185 » Fri Feb 16, 2007 5:39 pm
alltrac7 wrote:can someone make this a sticky??????????
Sure
http://alltrac.net/phpBB2/viewtopic.php ... ight=brake
Add this to the brake info
^Ted^
Denver_whiteST185
Postby sleeper » Fri Apr 06, 2007 12:34 pm
do you have a picture of the Aluminum rear diff mount?
or where to get one?
sleeper
Postby CMS-GT4 » Fri Apr 06, 2007 12:51 pm
Search for Mario Konig. He has a few threads here with his info. He makes the mounts. There are also a couple other versions. TRD made a poly version, and I beleive once of our sponsors also made a polly version.
