Alltrac Handling FAQ
Postby lumbercis » Wed Aug 27, 2008 3:25 am
Suspension and chassis development link from National ProSolo champion:
http://farnorthracing.com/autocross_secrets.html
Caldina powered...
lumbercis
Postby CMS-GT4 » Thu Feb 05, 2009 4:48 am
A good read on suspension functions and types.
http://www.carbibles.com/suspension_bible.html
Postby smog7 » Wed Feb 18, 2009 4:50 am
-omar
rally tarmac 1990 st185
smog7
Re: Alltrac Handling FAQ
Postby Xiansheng » Mon Aug 01, 2011 10:38 pm
Does the RC have it's own alignment settings, I have to get alignment right away and dont know what to do.. just let them do it.. or actually give them the numbers...
is usdm alltrac figures that they probably will use ok for RC, I read somewhere in the press release for RC or somewhere, it has different camber etc settings.. so I'm lost here guyz.. please help
I would like to have the RC alignment to stock toyota settings how it came from the factory know what I mean.. th car is pretty much stock at this point.
Thanks.
'91 GT-Four RC
Xiansheng
Postby Corey » Mon Aug 01, 2011 10:55 pm
You should be able to find the whiteline recommended specs for our cars. They spent a good deal of time testing different settings and published them a number of years ago.
Edit: Here they are
viewtopic.php?t=23040
Corey
Images: 50
Postby Xiansheng » Tue Aug 02, 2011 12:39 am
Thank you very much!! I don't know how I missed that thread.. I searched like a crazy man.. I suck. :notworthy:
u da mAN!!
'91 GT-Four RC
Xiansheng
Postby Xiansheng » Tue Aug 02, 2011 1:03 am
hmmm so on a stock st185 RC built Sept. '91 should I set the car to the suggested Wheel Alignment Settings of Whiteline's handling pack?
http://www.whiteline.com.au/do_segue.ph ... 89-12%2F92
even though I'm stock those settings are good?
'91 GT-Four RC
Xiansheng
Postby aus jd 2703 » Mon Jun 25, 2012 11:14 pm
instead of starting a new thread i thought id ask here.
will st184 front swaybar fit in a st185? i cant see why not but i wanna be sure before i rip one out?
also how many different thickness sway bars are there?
thanks
aus jd 2703
Postby Meenya » Fri Dec 21, 2012 9:27 pm
Just received my Cusco rear top mounts and uploaded a few pictures, in case someone wants to see what they look like before ordering.
Larger pictures can be seen in the gallery.
It says TRD on the sticker with 2 washers in the plastic bag.
512
513
514
515
516
517
Mike
93 Turbo 4WD
91 GTFour RC
07 R6
Meenya
Images: 19
Postby Rallly » Tue Mar 15, 2016 4:32 pm
Can someone posted the factory alignment specs for a 91 st185 alltrac widebody and also maybe a "better handling" alignment specs also.
Rallly
