Stock 6th and 7th Gen Celica Wheel Info
Postby b00staholic » Tue Sep 13, 2005 2:17 pm
Hey guys,
I'm interested in getting a set of dedicated autocross/track wheels/tires and stock 6th or 7th gen Celica wheels look to be the cheapest option.
Can you guys tell me the:
1) Width
2) Offset
3) Weight
of the 15" 5-spoke 6th gen wheel, 15" GT rim from the 7th gen and the 16" 7th gen GT-S wheels?
I read a post somewhere on here that said the 15" 5-spoke 6th gen wheel was 7 inches wide, but I wanted to verify that.
Thanks.
Vincent
'90 ST185
b00staholic
Postby Gary » Tue Sep 13, 2005 11:49 pm
7th gen:
- GTS 16x6.5 39mm 19 lbs.
- GT 15x6.5 39mm
6th gen:
15x7 45mm
5th gen:
GTS, Alltrac 15x6.5 39mm
93 ST185
Gary
Postby tweekgt4 » Wed Sep 14, 2005 12:59 am
i don't recommend 7th gen gts rims because the rim itself was like 22 pounds (when i weighed the rim, might have been 19 like gary said).
also 16x6.5" doesn't leave much room for fat tires.
1999 Volvo V70R, Laser Blue
2001 BMW M5, Titanium Silver
http://www.brsf.net
tweekgt4
Postby b00staholic » Wed Sep 14, 2005 4:30 am
That's interesting that they went to a 7" wide 15" rim for the 6th gen. Too bad the offset isn't as low as the other Celica wheels.
Anyone know the weight of the 6th Gen 15x7 wheel?
Vincent
'90 ST185
b00staholic
Postby Rick89GTS » Wed Sep 14, 2005 5:05 am
I run the 6th gen OEM 15x7" rims on my 165 with 205/55/15s.
Gary's right, they are +45 offset, whereas stock for my 165 is +39. They rubbed the rear struts, so I had to use thin 1/8" spacers. No biggie :smokes:
PS - I weighed them before but don't recall how much, sorry.
Also, note that the 7th gen GTS rims are +39mm offset.
Rick89GTS
Postby Gary » Wed Sep 14, 2005 6:07 pm
My bad for the offset.
When I weighed them, my scale is like +/- 2 lbs.
93 ST185
Gary
Postby b00staholic » Thu Sep 15, 2005 6:32 pm
Thanks for the info, Rick.
Would you say that they are over or under 20 lbs. each?
And does anyone know if they would fit an ST185 without any rubbing or fitment issues due to the 45 mm offset? Especially if I put a 215 or even 225 tire on there?
Vincent
'90 ST185
b00staholic
Postby Rick89GTS » Fri Sep 16, 2005 3:52 am
I'll weigh one of them tomorrow and post up again.
What is the stock wheel size and offset for the 185?
If you know that, you can compare it against the 15x7" (205/55/15) +45mm offset to get a pretty good idea.
Rick89GTS
Postby Rick89GTS » Sat Sep 16, 2006 8:57 pm
b00staholic wrote:Thanks for the info, Rick.
I'd say right about 20 lbs for rim only.
The 7th gen rim + tire = 37 lbs total.
Rick89GTS
Postby jlspec » Mon Sep 18, 2006 4:34 am
Here is the 6 gen wheels on my car. No rubbing and I have 225/50/15 on all four wheels.
jlspec
Postby Razzo » Mon Sep 18, 2006 5:59 am
jlspec wrote:Here is the 6 gen wheels on my car. No rubbing and I have 225/50/15 on all four wheels.
Nice thats what i'm going to do for my winters. Do you think i could get 235/245 with the gts rim. Very nice alltrac btw
Razzo
Postby 88st165 » Mon Sep 18, 2006 7:45 pm
i would have to say no to the 235/245s on the gts rims because when the tire shop was doing my gts rims they had a hell of a time even getting 215s on. also i would think 235/245s would be way to wide of a tire to run on a 6.5" wide rim assuming you are talking about the 7th gen gts rims.
Black st165 - gone
2011 FA5 - Family Truckster
88st165
Images: 2
Postby Razzo » Mon Sep 18, 2006 7:53 pm
talking about 6th gen, which are 7'' wide. Sorry i'm not guru when it comes to tires :P
Razzo
Postby AlltracAvenger » Mon Sep 18, 2006 10:37 pm
Hm.... does anyone have a benchmark as to what the stock ST165 and St185 wheel/tire combo weighs? I wasn't able to weigh mine, but having that benchmark might be a good thing for those looking for lighter wheels.
'88 ST165 #2914- Sold 12/21/06 :(
'88 ST165 #3784- Bought 05/08/15 :D
'05 Corolla XRS- Daily Driver
AlltracAvenger
Postby Gary ST165 » Tue Sep 19, 2006 9:09 am
Wheel offsets for the Celica range…
* Gen 4 , ET39.
* Gen 5 ,pre-facelift 14 x 6, ET45mm offset
* Gen 5, Facelift… 15x 6,ET 45mm offset
* Gen 5, GT4 Carlos Sainz, 15 x 6.5 , ET 39mm off set
* Gen 6, GT, 15 x 7 ET 45 mm offset
* Gen 6, GT4,16 x 7, ET 45mm offset
* Gen 7, 16″ 5 spoke,16 x 6.5, ET 39mm offset
* Gen 7, 17″ sports pack,17 x 7.5, ET 38mm offset
ST165 turbo 4WD
Gary ST165
Users browsing this forum: FlannelFairlady and 4 guests
