Active member
Stock alltrac/gt4 power dist. is 50/50. To reduce nose plow, and make the car handle better in the tighter turns (short course), over steer needs to be induced in the alltrac.
As much can be done to the suspension and rear lsd can be added to help in this, but I feel the alltrac can use more.
I was looking into having the gear ratio in the center diff modified to change the power split. Not sure how much it would cost, but I am sure it would not be cheap.
I was thinking F35/R65.
Since this is going to be a track car (mostly autox) the reliability issues on the center diff are not as much of an issuse. The fluid in the center diff can also be upgraded to handle more stress like the trd units.
I was thinking about the tire size difference on some cars in the gt4 hyper rev mag. They run wider/ larger dia. tires in the front vs. the rear.
I see this as a cheap way to change the front to rear rolling ratio to act simular to adjusting the power split.
For exaple.
I am running 205/40/17 on a 17x7" wheel. (This is the same ratio as stock) Split is 50/50
Here is a tire/wheel size listed in Hyper rev.
This is the garage cruise gt4
Wheels (17x9.5)
Tires F(225/40/17) R(245/45/17)
Since the dia. of the rear tire is larger the wheel is moving at a faster rate.
Here is a link for reference.
http://www.miata.net/garage/tirecalc.html
I think I am catching on to this correctly, but give me an idea of what you guys think. This may be one of the key secrets to making the gt4 handle. This may also explain why Bob has larger tires in the rear.
For exaple.
Wheels (17x9.5)
