alltrac101
Member
>Cause I am not sure there is enough room to remove the 5x115 studs and piece once they are installed.
I'm not sure what you mean?
To do what I want, the hub will need to be pressed out, install the new 10 hole ring from behind, then reinstall.....10 hole will definately work with both patterns
Pat
Pat
