Hub Project to make us wheel options (5/100 to 114.3)
Re: Hub Project to make us wheel options (5/100 to 114.3)
Postby tubasteve » Thu Apr 12, 2012 4:41 am
No, wait 300, that is the poor mans 205 swap :-(... In looking into 316+
tubasteve
Postby CMS-GT4 » Thu Apr 12, 2012 4:45 am
Are you working with a bracket or something. I was under the impression nothing over 307mm will fit.
Postby tubasteve » Thu Apr 12, 2012 5:21 pm
Working to get the 205's to get bolt on with hub swap like i did for the 185. and on the st205 to bolt onto the 185 using little modification. I'm just fighting my self a bit for safe and cheap.
tubasteve
Postby CMS-GT4 » Sun May 27, 2012 9:50 pm
So I am trying to figure out how much disc the SVX rotors allow for the pad sweep. These rotors are still about $25 each, so paying to get the center bore machined to 62mm should not add that much more to the cost and still makes them a budget rotor.
I have also been kicking around the idea of supra rotors. There was a russian forum that drilled a new mounting hole in the 205 calipers then cut the ears down so they could use a bracket to attach the spindle.
I think one way I could accomplish this is make a guide metal that had 4 holes. Two holes would bolt into the stock location and then it would hold the new guide holes in place. I could use a drill press to make new holes and thread them. I am now sure what to use to cut the ears down though.
Then I would just have to fit it on the supra rotor and measure for a bracket.
gtfourtc wrote:I just checked out that link, here are a couple more pics of that bracket setup, its not as simple as a bracket they modified the caliper
to have 4 smaller bolts connect to the caliper in different places than the oem mounting holes.
Uploaded with ImageShack.us
Of course that is a lot of work, and sort of defeats the purpose of these calipers so I am still not sure what my plan is.
EDIT:
After looking at the svx rotor and pad size, I think a lot of pad sweep area would be wasted using this rotor.
Postby tubasteve » Mon May 28, 2012 5:10 am
^ working on this exact plan as we speak
tubasteve
Postby aus jd 2703 » Mon May 28, 2012 8:53 am
I'm trying to fit the 205 calipers with 315mm rotors as I want full size rotors. But I'm planning custom hats on two piece rotors. Just gotta work out spacing
aus jd 2703
Postby CMS-GT4 » Mon May 28, 2012 1:51 pm
tubasteve wrote:^ working on this exact plan as we speak
If you look at the linked thread there is a drawing of the bracket and all dimensions.
Edit here is the drawing: I am curious if there is a strength difference over using 4 bolts over 2. I imagine the caliper is just as strong as the tension point would change to a higher/thickersection.
viewtopic.php?f=8&t=21323&start=75
And the actual russian thread:
http://www.caldina-turbo.ru/forum/showthread.php?t=4063
Postby tubasteve » Wed May 30, 2012 12:36 am
thanks, i have those posts and the pictures, im just using a supra rotor as i want to use supra pads and supra rotors XD.
THANKS A MILLION on the help though.
-jr
tubasteve
Postby Cuttyman9 » Tue Feb 19, 2013 3:00 pm
Alright so sorting through this has brought me to the conclusion that I need rav4 hubs trimmed as pressed into celica bearings to swap the front on my 2wd celica. It's stock drivetrain wise, my plan is to swap the rear first then get another spindle assembly and install the other hubs so if the ones with the 5x114.3 fail I can swap my old ones on and be good to go till I fix the 5x114.3.
Being that this doesn't pertain to the awd variants, the rear needs to be from a Camry using a Camry brake rotor? I've looked up the brake rotor size and shape and they appear to be identical aside from the bolt pattern.
I'm hoping that this would be that simple.
1992 Celica GT Hatch
1971 Cutlass
1967 Chevelle
1975 Trans Am
1966 C20 Long Bed
1999 F150
Cuttyman9
Postby monkey8oi » Mon Apr 25, 2016 7:01 pm
subscribed..
monkey8oi
