Afr reading
• Page 1 of 3 • 1, 2, 3
Afr reading
I just finished rebuilding mt st165, I finally got my prosport wideband installed and I am trying to understand my afr readings. I have q jdm engine, stock ct26 running 15 psi, New everything on the motor prosport boost gauge, walbro 255lph fuel pump, straight intake and a 3" Aussie Dp. When I'm cruzing it reads around 14.7 under max boost around 10.0 and when I let off to slow down its reading 20.0. I did have some problems with my last maf, maybe I need to adjust the new one.
| Members don't see the above ad. Register now - it's free! | |
mine is the red one on the left
jaydog82 - Club Member
Re: Afr reading
Off throttle does cause this, 14.7 isnt bad I like a 14.5 idle, but when do you see 10.0? That's a bit rich at certain areas on the throttle map
1990 ST185 All-Trac 54trim
1993 Nissan Skyline R33 GTS25T-M widebody built 60trim R34 NEO AEM-Series 2
OutToWinPAHC - Club Member
Re: Afr reading
it seems ok, but like the OutToWinPAHC said 10:1 is a bit at the rich side.
no problem to run it, but your car will be faster if you can adjust it to the 11:1 - 11.5:1 mark with a SAFC or another simple piggyback
[IMG]http://i.imgur.com/emTLn.jpg[/IMG]
Mehmet Ali Ovacikli
istanbul / TURKEY
zürich / SWİTZERLAND
Mehmet Ali Ovacikli
istanbul / TURKEY
RoAdbOy - Club Member
Re: Afr reading
Ya that's what I was thinking, what about adjusting the maf? I read that you can lean it out by adjusting the spring inside the maf.
Re: Afr reading
jaydog82 wrote:Ya that's what I was thinking, what about adjusting the maf? I read that you can lean it out by adjusting the spring inside the maf.
yes of course you can
i myself use SAFC too
but watch out; do not set it more lean than %10
only small touches
Mehmet Ali Ovacikli
istanbul / TURKEY
Mehmet Ali Ovacikli
istanbul / TURKEY
Re: Afr reading
your conditions are completely normal for a stock ecu
Built Gen 1 3SGTE,Megan,Autopower,Forza,Precision,Haltech,COP,Racepak,FMIC,Nitto,CRW axles,Quaife,V6 trans,Competition Clutch,Fidanza,Moroso,ST,370whp,340tq
Sponsors: Midas, SRT, Paradise Racing, CRW, ST162.net
Mafix - Gold Member
Re: Afr reading
jaydog82 wrote:Ok, is 15 psi the max I should run?
i think 15-16psi is enough for a stock ct26
Mehmet Ali Ovacikli
istanbul / TURKEY
Mehmet Ali Ovacikli
istanbul / TURKEY
Re: Afr reading
i'm not familiar with your car. generally on a stock gen 1 no more than 1 bar.
Mafix - Gold Member
Re: Afr reading
I have a 1st gen jdm motor, low mile ct26 with very little shaft play, all new gaskets seals hoses ext, New fuel pressure reg and damp, walbro 255 lph pump, cleaned and ballenced injectors, OEM spark plugs, New cap and rotor, magnacor wires, spec stage 2 clutch, rebuilt drive shaft and cv shafts, redline lightweight shockproof gear oil in the trans and diff, redline syn oil in the engine, ate super blue brake fluid, wta ic pump constant run mod with a 10" fan on the heat exchanger, 3" Aussie Dp, mbc set to 16 psi, straight intake with a arm dry flow filter and a shadow special catch can, battery relocation to the trunk, pro sport egt- boost and wideband gauges, all aluminum asi radiator from the c tech group buy, New Toyota thermostat, braided steel clutch line, ebc red stuff brake pads.
I plan on installing a water/meth injection and a 2.5" full exhaust, then start going through my suspension.
That's all I can think of for now for my mod list.
Re: Afr reading
that already is far beyond the computers capability. the st165 just goes full dump past 1 bar of boost. fyi.
Mafix - Gold Member
Re: Afr reading
^ but if he isn't hitting fuel cut then does the ecu even know?
1987 GT-S -> rust in piece
1991 RC -> project http://www.alltrac.net/phpBB2/viewtopic.php?f=44&t=44216 "Darlinda the Tie Fighter"
1992 GT-S -> daily
2000 Cherokee -> ski hauler
1997 Prelude -> girlfriends daily/project "Charmeleon"
1992 GT-S -> daily
- Established Member
Re: Afr reading
^ I have the stock boost sensor unpluged for now, untill I can get my dyi FCD installed.
Users browsing this forum: Bing [Bot] and 1 guest
