Code 54 anyone?
Code 54 anyone?
Postby CelicaCS » Wed Nov 23, 2005 1:02 pm
Hi,
Sometimes my 'check engine' warning light came on, so I checked the code, and it displayed 54. According to my manual it's a "IC motor stop". Has anyone got a remedy for this issue? I checked the steps from the manual (IGN fuses, IC fluid levels etc.).
I used TFS ;) but it ain't a coolant level problem
Toyota Celica ST185 Carlos Sainz ed. 2046/5000
CelicaCS
Postby Conan » Wed Nov 23, 2005 1:46 pm
Have you tried the Search function? :D
Conan
Postby CelicaCS » Wed Nov 23, 2005 3:28 pm
Conan wrote:Have you tried the Search function? :D
Have you tried to understand internet slang? :doh:
:P
What do you think TFS stands for as in I used THE Feckin' Search (UTFS)?
CelicaCS
Postby rightrac » Wed Nov 23, 2005 3:38 pm
my search for "code 54" gave me plenty of hits including: http://www.alltrac.net/phpBB2/viewtopic.php?t=9541&highlight=code
heres some more internet slang for ya... NOOB!!
:D
rightrac
Postby Mafix » Wed Nov 23, 2005 10:31 pm
all in good humor.
Postby CelicaCS » Thu Nov 24, 2005 5:43 am
rightrac wrote:my search for "code 54" gave me plenty of hits including: http://www.alltrac.net/phpBB2/viewtopic.php?t=9541&highlight=code
:D
STFU
That was the ONLY useful hit my dear fellow NOOB....
And I also told you that I had visited that one already....
All in good humor, indeed, but quite useless when it comes to solving my problem unfortunally :D
I solved it myself already. It's the IC coolant level sensor on the wta ic that's busted.
CelicaCS
Re: Code 54 anyone?
Postby underscore » Sat Jun 11, 2011 11:25 am
Massive bump here to avoid making a new thread.
I've been tossing a code off and on since I cleared out my intake and exhaust leak ones. It's the 54 obviously so something to do with the water-to-air system, it only seems to come on when moving and goes away when I restart the car or I'm at an idle long enough. I seriously bog down at lower revs until the turbo starts to spool a little bit and gets me up off of full vacuum. I've got the water filled all the way to the top and when I ran it (parked) with the float out but placed upside down there was no code, and when I use a wire to jumper the plug that the float hooks into I don't get a code and the car runs great with no bogging.
I'm just wondering if I can damage anything by bypassing the float when I know that the water is all the way to the top? I'm also only hitting 7PSI in 3rd and up but I was able to hit 11 once when the CEL went away. I'm guessing this is an unrelated issue with my TVSV? Or is my car limiting my boost (albeit not as badly as when there's a CEL) because of the shorted WTA float?
