ST165 to ST185 ECU Conversion
Postby All4Traction » Tue Jan 24, 2006 3:34 am
:D :D :D :D :D :D :D
Well, I wired up my 185 ecu to my 165 harness and it started up in -10deg. celcius!
I have to wire the IC pump constant and then take it for a test drive tomorrow.
Here's a pic of the adapter harness i made so I didnt have to hard wire everything up in -20 to -35 deg. Celcius weather. Also it allowed me to switch back to my 165 ecu if it didnt work.
Image[/quote]
Paul S.-
89 Celica Turbo 4WD- Jdm ST-185 swap, CT20B turbo, ST205 A2W I/C....
http://turbo4wd.topcities.com/
All4Traction
Postby turbo4wd » Tue Jan 24, 2006 3:40 am
What did you use to make the adapater harness? Aside from all the wire, I mean primarily the connectors..
Dan
Undercover Moderator
turbo4wd
Postby All4Traction » Tue Jan 24, 2006 3:44 am
The green plug is the guts of a 3sge ecu, then i had to re-arrange pretty much all of the pins, then i soldered the corresponding wires to the 185 ecu plugs.
Ill have to see if my a/c still works as well.
No check engine light lit up either :evil:
Paul S.-
All4Traction
Postby beej » Tue Jan 24, 2006 12:04 pm
wow good job dude.....thats alotta effort
"ITS A VENT GODDAMIT NOT A F#$KING SCOOP!!!!!"
beej
Postby 88st165 » Tue Jan 24, 2006 2:02 pm
wow really good job.... if all goes well maybe you should start producing these....
Black st165 - gone
2011 FA5 - Family Truckster
88st165
Images: 2
Postby Cashback » Tue Jan 24, 2006 3:14 pm
I would buy one.
Cashback
Postby All4Traction » Tue Jan 24, 2006 5:28 pm
The only trouble is finding all of the 185 harness plugs and finding a bunch of 1st gen 3sge/3sgte ecu's to take the female plug out of.
If you find both, I would probly be able to do it.
I still have to fully test it today though.
Paul S.-
All4Traction
Postby Flyin' Bryan » Wed Jan 25, 2006 3:49 am
Well i figure you could get the gen2 plugs from a 5th gen auto GTS, and a lot of Toyota ecus use the gen1 ecu connector. Good work Paul, can't wait to see it for myself.
Bryan B.
2014 Ford Fiesta ST
1992 Celica GT-Four
1992 Celica GT-Four-Sold
1989 Celica turbo 4WD-Gen III swap, Sold
1988 Celica turbo 4WD-Rotted away
1988 Celica turbo 4WD-Parts
Flyin' Bryan
Postby All4Traction » Wed Jan 25, 2006 3:51 am
Ya, thanks Bryan, it was a team effort :D
Paul S.-
All4Traction
Postby D_oPsycho » Wed Jan 25, 2006 5:53 am
If you seriously consider producing these harness adapters, I am in very close proximity to 4 junk yards, and all of them have numerous Toyotas, and I know there are many cars in there with the plugs you need. Come this spring when everything isn't covered in a foot of snow, I can scout them out, see how many I can grab up and send them to you, I can prolly get each one for a few bucks
ST184 1991 Celica GT 5S-FE
It might not be as fast as you guys, but it still beats any Civic I've met up with :)
D_oPsycho
Postby Cashback » Wed Jan 25, 2006 3:32 pm
I'm also near some junkyards and since I'm in Florida snow isn't an issue. If you can tell me exactly what you need out of what car I can go down there this weekend and pull whatever you want.
This adapter may be super awesome if it allows me to run an AEM or E-Manage on my 165. So I'm down to help make another one and then experiment from there.
Cashback
Postby Gurr » Thu Jan 26, 2006 9:29 pm
Well, I've seen people puttin the 205 ecu with the 185 harness, is there anyway to get it to work with the 165 without to many problems? It would be a way to get rid of the nasty AFM and use 540/550's relatively safely. Just wondering...
Thanks
Brian
White 165.
Working out the 2g head/turbo swap kinks right now. *hates wiring problems*
Gurr
Postby All4Traction » Fri Jan 27, 2006 5:48 pm
You would need to get a lot of the 205 sensors.
If its been done with the 185 harness, it could be done with the 165 with about the same effort. The 2 165/185 ecu's and harnesses arent very different.
Bryan (Flyin'Bryan) Is using his 165 harness to wire his 205 ecu to the 205 motor, but it required a lot of the harness to be rewired.
Paul S.-
All4Traction
Postby 98RACE » Wed Feb 01, 2006 2:22 am
Why is putting a 185 ECU on a 165 motor better??
I think I may be missing something!! :shrug: Could you fill me in??
98RACE
Postby All4Traction » Wed Feb 01, 2006 3:48 am
Oh, sorry, i have the 185 motor, but i was runnin the 165 ecu, which i didnt like the idea of.
Paul S.-
All4Traction
