ST165 to ST185 ECU Conversion
Postby 98RACE » Wed Feb 01, 2006 12:20 pm
All4Traction wrote:Oh, sorry, i have the 185 motor, but i was runnin the 165 ecu, which i didnt like the idea of.
I was thinking that was the situation but I thought I would ask..
98RACE
Postby 88st165 » Fri Feb 10, 2006 9:06 pm
any other news on how its been working?
Black st165 - gone
2011 FA5 - Family Truckster
88st165
Images: 2
Postby maxaud » Fri Feb 10, 2006 9:23 pm
props on the wiring... I definately would of had my All-trac up in flames if I tried anything like that... what's w/ the temps that you speak of (starting temps)... do they have to be a certain temperature to start the car? I'm lost... (as always)
-Dustin
maxaud
Postby All4Traction » Sun Feb 12, 2006 5:12 am
Everything is workin great, i grounded my IC waterpump so its on all the time. I have had absolutely no problems, it runs a lot smoother under partial throttle now, probly since i was runnin the 185 isc.
My A/C doesnt work, but the light for it does come on. I think ill just have to put a manual switch to turn the pump on.
maxaud wrote:props on the wiring... I definately would of had my All-trac up in flames if I tried anything like that... what's w/ the temps that you speak of (starting temps)... do they have to be a certain temperature to start the car? I'm lost... (as always)
Haha, no i just stated that is was pretty cold outside when i started the car.
Paul S.-
89 Celica Turbo 4WD- Jdm ST-185 swap, CT20B turbo, ST205 A2W I/C....
http://turbo4wd.topcities.com/
All4Traction
Postby maxaud » Sun Feb 12, 2006 5:22 am
I've seen a lot of people stating temps like that so I thought I would ask.
-Dustin
maxaud
Postby Mafix » Mon Feb 20, 2006 2:16 am
well if you rewire to a 185 ecu and get it to work then you can always use PnP systems like the aem!
Postby Toxygene » Thu Mar 02, 2006 9:22 pm
Hmmm can't see why your AC wouldn't work? Sure there isn't a way to make it work through the ECU?
Toxygene
Postby allblackalltrac » Thu Mar 02, 2006 10:54 pm
Paul
I sent you an email did you recieve it? Im haveing some issues with my email lately...
-Danny
SupraCelifragilisticexpialidocious
super- "above," cali- "beauty," fragilistic- "delicate," expiali- "to atone," and docious- "educable," the sum meaning roughly "Atoning for extreme and delicate beauty while still being highly educable."
allblackalltrac
Postby Mafix » Thu Mar 02, 2006 11:53 pm
so are you going to make some of the 165 harness to 185 ecu adapters...cause if not i'm gonig to have to make one. lol.
Postby eric thompson » Fri Mar 03, 2006 12:43 pm
i have three 165 ecu's ,also one complete 165 harness and one cut near the ecu plug area(jdm swap)- my current harness is a completely custom 165 harness(by custom i mean it was built from scratch by a rally team with two quick disconnects for easier engine swaps between stages). as much as i would like to go stand alone- its probably less expensive to do a 185 ecu as there is more aftermarket support with electronics for the 185ecu. whats the chances of getting the same setup???
ST165-PARTS-RED
NEED ONE MORE FOR STREET:)
https://www.youtube.com/watch?v=w-RCuV_Hmqk (ITS miata 6spd,4.78 rear, shitloads of fun!! multiple wins and track records in 2014)
eric thompson
Images: 6
Postby polarmoment » Sun Mar 05, 2006 6:42 pm
for what it's worth, OBDI hondas use the exact same plug as the toyotas. a lot of the civic/common ecu's are hard to find, but there are some bastard child boxes that no one wants that should be pretty cheap.
the plugs are made by AMP/tyco too, so if you're doing a large volume of them you may be able to get your hands on them from the manufacturer.
polarmoment
Postby polarmoment » Mon Mar 06, 2006 4:56 am
female receptacle is amp/tyco part # 174518-7
the male plugs are part #'s 174514-6 (16 pin), 174515-6 (22 pin), and 174516-6 (26 pin), with contacts being part #'s 173631 (large) and 173716 (small). you'll need 16 of the larger and 48 of the smaller ones.
polarmoment
Postby allblackalltrac » Mon Mar 06, 2006 6:00 pm
polarmoment wrote:female receptacle is amp/tyco part # 174518-7
OMFG - BEST POST EVER!
Thank you so much for sharing that bit of information, I have spent years trying to find this.
allblackalltrac
Postby polarmoment » Tue Mar 07, 2006 3:39 am
i can do even better than that :D
www.onlinecomponents.com stocks all these parts.
the female plug costs ~$6
the male plugs cost ~$1 each and the pins are about 4-5 cents each and they have no minimum order.
polarmoment
Postby allblackalltrac » Tue Mar 07, 2006 5:00 am
not to get OT but I vote polarmoment rookie of the year
allblackalltrac
