ST165 to ST185 ECU Conversion
Postby All4Traction » Sat Mar 11, 2006 4:57 pm
Hey guys, i havent been around for a while, i would be very interested in producing these, but... im in my last few months of graduating school and time is a limitation, i might be able to get a couple done, but once May comes along i probaly wont have access to the internet where ill be workin :(
Paul S.-
89 Celica Turbo 4WD- Jdm ST-185 swap, CT20B turbo, ST205 A2W I/C....
http://turbo4wd.topcities.com/
All4Traction
Postby DangerViking » Sun Mar 12, 2006 3:37 am
I'm about to start on installing a 185 motor into my 165 this weekend, and I am going to need to make one of these for sure :) If it's not too much trouble, do you have a wiring diagram that you used? I've read Chris' writeup on the harness conversion, and looked at the pinouts for both, but if you already have something, it'd make life soooo much easier :)
88 ST165, white, #6816 - (For Sale/Trade)
88 ST165, white, #5416 - gone
78 Datsun B210
98 Subaru Impreza 2.5RS
Chandler, AZ
(AllTrac.cheap && AllTrac.easy) = 0
DangerViking
Postby DangerViking » Sun Mar 12, 2006 3:31 pm
I just went over everything again on the pinouts for each gen's ECU, and assuming everything else swaps over, the only things I'm unsure of are:
ST185 ISC Valve connections (RSC and RSO) to ST165 ISC Valve connections (ISC1 and ISC2)... which goes to which?
ST185 OX2 connection (Check connector, assuming for O2 sensor).. does it connect to anything?
ST185 VC connection (Sensor power source).. just hook this to switched power (like the +B connector)?
ST165 E22 connection (sensor ground).. does this go anywhere?
ST165 FPU connection (Fuel pressure VSV).. does this go anywhere?
ST165 VS Connection (Air flow meter).. should be the last one that I can't find a connection for on the 185 ECU.
Other than this stuff, is there anything else crazy that I would need to know? What did you do about the fuel pump relay and resistor, or does just swapping the connections over and using the stock 165 harness take care of this? which, if any, sensors needed to be swapped over? Did you have to swap any plugs on the engine side of the harness? Thanks again, and sorry for all the questions :) Hopefully once all this is done, I'll be putting together a writeup on how to get it all done.
78 Datsun B210
Chandler, AZ
DangerViking
Postby All4Traction » Sun Mar 12, 2006 10:33 pm
RSC=ISC1
RSO=ISC2
I didnt connect OX2 to anything
VC goes to VC
E22 can just be grounded
FPU is scrapped
VS goes to VS
I wish I had time to do a thorough write up and even produce these.
Next winter ill have lots of time
Its quite a simple job though, im suprized I was the first to do it.
Paul S.-
All4Traction
Postby DangerViking » Mon Mar 13, 2006 1:37 pm
Thanks for the info :) I'll hopefully be making one of these really soon, as soon as I get all my wiring/vacuum stuff hooked up to the second gen engine, and I'll get a writeup made.
78 Datsun B210
Chandler, AZ
DangerViking
Postby DangerViking » Fri Apr 07, 2006 3:04 pm
polarmoment wrote:female receptacle is amp/tyco part # 174518-7
the male plugs are part #'s 174514-6 (16 pin), 174515-6 (22 pin), and 174516-6 (26 pin), with contacts being part #'s 173631 (large) and 173716 (small). you'll need 16 of the larger and 48 of the smaller ones.
I was going to order everything from onlinecomponents today.. for 17361 they show:
Part Number Manufacturer Quantity On Hand
17363-1 AMP / TYCO
173631-1 AMP / TYCO 3704
173631-2 AMP / TYCO
173631-6 AMP / TYCO 18730
173631-7 AMP / TYCO
and for 173716 they show:
173716-1 AMP / TYCO 11321
173716-2 AMP / TYCO
I'm just going to buy some of each of what they have in stock, just not sure exactly which part # I should get, or if it matters?
78 Datsun B210
Chandler, AZ
DangerViking
Postby Qlynxer » Fri Apr 07, 2006 9:27 pm
I tried ordering a plug from onlincomponents and decided not to because the minimum is 30 dollars.
Quan L
Santa Ana Ca
Qlynxer
Postby Cody Mamak » Sat Apr 08, 2006 10:37 am
Hey, I just read the reply to my thread and went over to this one. :wink:
Please All4Traction or someone, could write down the full list of pin corrispondency between 165 and 185 ECUs or link to some documents about this matter? :D
Also, any downside using this converter (that might save up the day for many many of us not having a 185-165 full harness to convert or some problems doing it or having a incomplete one and so on... ) so far?Any issue about having different fuse boxes or any component that is just different / works in a different way in the 2 harnesses / ECU signals ?
Anyway I want to just say that this workaround is great, proops to All4Traction :smokes:
BTW, any idea of where to find correct plugs /components would be good, since 30 dollars orders online is stupid IMHO :shoots:
Cody Mamak
Postby Qlynxer » Sat Apr 08, 2006 8:09 pm
Here's a link showing the pins for 165 and 185 ecus. http://www.alltrac.net/reference/
If you look at the two diagrams you'll begin to see that most of the pins on the 165 ecu are also on the 185 ecu, they're just in different places.
Good luck Quan L
Santa Ana Ca
Qlynxer
Postby All4Traction » Sun Apr 09, 2006 6:52 am
Qlynxer wrote:Here's a link showing the pins for 165 and 185 ecus. http://www.alltrac.net/reference/
Good luck Quan L
Bingo, and on another thread somewhere, i explained what to do with the "extra's" that dont correspond.
Edit: :doh: I explained those above, haha.
Paul S.-
All4Traction
Postby All4Traction » Mon Apr 10, 2006 10:03 pm
Today i got my AC working, i guess a wire came out of one of my AC plugs, HAHA, so i guess it wouldnt have worked before i switched ecu's :P
Paul S.-
All4Traction
Postby DangerViking » Sun Apr 16, 2006 3:50 pm
just got my connectors and plugs this week and *fingers crossed* may be getting a sample of the female 165 ECU plugs soon.. if so, I'll post on here about how I got them :)
78 Datsun B210
Chandler, AZ
DangerViking
Postby celicast3sgte » Sun Apr 16, 2006 9:13 pm
Anyone in this thread interested in a 205 ecu?! i got one laying around I dont want it, im running standalone. PM me if your interested. I have a harness like the one u made specifically for rewiring these ecus to other models.
celicast3sgte
Postby Qlynxer » Sun Apr 16, 2006 9:25 pm
I was able to get some female plugs of a MK3 Supra ECU, i can also confirm that first gen eclipse GT had the same type of ecu. I also have two of the three male plugs. Still looking for that for that last one however.
QUan L
Santa Ana Ca
Qlynxer
Postby DangerViking » Wed Apr 19, 2006 4:42 pm
I got em!!! they came in the mail yesterday, two brand new female 165 ECU connectors, no scavenging needed. I went to Tyco/Amp's website, and under their questions page, there's a link to ask for samples, so I wrote:
I am attempting to build a prototype standalone Electronic Control Unit for several vehicles which use part number 1-172319-7. If possible, I would like to investigate purchasing or receiving a few samples of this connector to complete the prototype and detemine feasibility for the project before making a large-scale purchase (600 is the minimum order that I have seen for this part number, and I will not need that many units until my proof of concept has been completed). If there is a way to make a smaller order of 5 or 10 connectors, I would be interested in that as well. Please let me know. Thank you!
While it wasn't *strictly* true, it was what they wanted to hear... two days later I got this email:
Response (Kass C.) - 04/10/2006 03:49 PM
I have place an order for 2 pieces, which is the max from our Japan sample room. You should receive these in about 7 days.
and I got the connectors a few days later. woo hoo! I'd suggest varying the story slightly so it doesn't look *too* suspicious, but it's worth a shot :)
78 Datsun B210
Chandler, AZ
DangerViking
