stock 165 jdm injectors
Postby Mafix » Wed Sep 22, 2004 2:20 am
anyone have any ideal what the stock flow rate is on these?
also i'm putting in a walbro 255 lph pump do i need to upgrade the fuel pressure regulator?
fuel filter...any high flow ones made for these?
i don't know these things :cry: .
thanks guys.
Re: stock 165 jdm injectors
Postby smc252 » Thu Sep 23, 2004 10:18 am
Mafix wrote:anyone have any ideal what the stock flow rate is on these?
thanks guys.
440cc/min.
You don't have to upgrade your fuel pressure reg., some do and some don't. On my fwd, I left in the stock st-165 fuel reg. Works fine.
What you can do about a fuel filter, find a nice 10-micron one that has an -AN inlet, and then get the two -AN to stock 3/8th fuel line adapter, just screw it all together, I am willing to do this for you and just send it to you, all you'd have to do is screw in the inlet and oulet where the stock one was. The stock fuel setup should be okay for 300hp, I'd go for 6-AN lines if you want up to 600hp worth of fuel, but the Walbro 255 won't support much over 500hp so far, as I have seen. Feel free to ask any other questions as well.
-Steve
1988 All-Trac
(Rotting away, fiending for a tranny.)
1986 Celica GTS
(GT3071R forced 3s-gte + autronic smc)
smc252
Postby Mafix » Mon Oct 04, 2004 10:24 pm
thanks steve...i'll be able to do that here. but good to finally know.
Users browsing this forum: Google [Bot] and 3 guests
