165 top feed injector options EXPOSED!
Postby GT4_CR » Mon Oct 09, 2006 3:43 pm
Im sorry guys but I cant see the pics very well to check the measurements of the injector.
I need high impedance for my DTA setup. Low impedance are no good and they screwed up my computer and resistor pack doesnt do its job.
I found Holley Injectors of 50lb/hr..thats something like 525cc
Its measurement is L7in x W5in x H 0.24
:shrug:
GT4_CR
Location: Costa Rica, Central America.. that little bridge between the north and the south. ( not puerto rico)
Postby GT4_CR » Thu Oct 12, 2006 2:46 am
GT4_CR wrote:Im sorry guys but I cant see the pics very well to check the measurements of the injector.
:shrug:
:cry: :shrug:
GT4_CR
DIY top feed for ST185's for ~$50
Postby polarmoment » Tue Jan 30, 2007 4:45 am
for the ST185's as well, the 5SFE top feed fuel rail has the same injector spacing as the 3SGTE side feed rail.
i'm using a 5SFE fuel rail, dsm 550's and to fit the injectors into the head, i cut the ends off a stock rail and used o-rings to seal them to the dsm injectors.
you'll need to use the 5SFE regulator with a splice from the 5SFE outlet to the stock fuel return, but the feed inlet is the same thread size (M12x1.25), as is the cold start injector outlet (M8x1.25).
for mounting, the 5SFE rail mounting surface is 38mm higher and 26mm offset from the 3SGTE rail. some 10mm bolts and pieces of 1/4"thick by 1" wide by 1.5" long aluminum drilled/tapped 26mm apart for the 10mm bolts makes mounting easy.
polarmoment
Re: 165 top feed injector options EXPOSED!
Postby ZeroDrift » Fri Aug 24, 2012 1:41 pm
Just to confirm: Stock ST165 injectors are high impedance?
Postby underscore » Fri Aug 24, 2012 4:09 pm
Holy thread bump Batman. Good info in that post from 2007 about a 5SFE rail on a 2g 3SGTE, I'll have to do that this winter.
Postby ZeroDrift » Fri Aug 24, 2012 4:14 pm
underscore wrote:Holy thread bump Batman. Good info in that post from 2007 about a 5SFE rail on a 2g 3SGTE, I'll have to do that this winter.
It is quite the bump! Its great info and honestly should be a sticky! Figure its better to bump a great thread with useful information than to make a new one.
Return to EFI Corner
