TSC & TVSV
TSC & TVSV
Postby gt4tified » Thu Oct 19, 2006 4:59 pm
How/Which sensor activates the TSC ecu signal...does it come directly from the TVSV?
gt4tified
Images: 5
Postby klue » Thu Oct 19, 2006 6:33 pm
i dunno i cant find tsc in any of my pinout diagrams. what is it?
Postby gt4tified » Fri Oct 27, 2006 12:06 pm
Check the pinout drawing here: http://alltrac.net/phpBB2/viewtopic.php?t=17114
Its on the top connector, 6th slot from the right.
gt4tified
Images: 5
Postby Gary » Fri Oct 27, 2006 12:42 pm
It works the other way around.
The ECU is not using just a single sensor.
It uses knock sensor, air temp sensor, coolant temp sensor, etc...
If the condition is right, the ECU activates the t-vsv by sending 12v to the t-vsv via tpc wire.
The vsv then opens and bleeds air out of the WG actuator and allows car to boost more.
(The t-vsv is normally closed)
BTW, it's TPC, not TSC
93 ST185
Gary
Re: TSC & TVSV
Postby underscore » Fri Sep 06, 2013 8:43 pm
Bumping this back up, what would happen if I had the TVSV signal wire unplugged from the ECU and tied to ground all the time? Would having the TVSV open when not boosting cause any problems?
The reason I ask is with my 3" exhaust I hit 15psi in 3/4/5, that's as high as I want to go so if I can do this to get 15psi in 1/2 then I can avoid buying a boost controller.
