As promised here is a brief summery of what the SMT7 can do and i wil also include some pricing information at the end:
Well the long wait is finally over! The SMT7 will be tested by me on the mr2 once i get it in mid november....after years of development and the success/shortfalls of the SMT6 have taught the Perfect Power team alot about what to do for its next product.
Here is some key features that will really benifit the MR2 market.
IGN MAP
Up to 2 balanced ignition signals (CRANK+CAM) can be intercepted and mapped via Throttle/RPM, AMP and Air temperature for the purpose of retarding/advancing the ignition.
This is great for proper modification of engines that involve timing to be adjusted with refrence of the CAM and Crank sensors (soon to have an additional DOHC support) Something the SMT6 lacked...
ANA1 MAP
An analog signal is intercepted via the A1IN/A1OUT connections and mapped via Throttle/rpm, AMP and Air temperature for the purpose of altering fuel at specific engine conditions.
With the adition of having Air temp and engine temp on the same table you are able to modify how much fuel comes in depending on the temp of your engine and can also be modified by the air temp (heat soak and such).... This will come in handy.....
OXY MAP
A narrow band lambda signal is intercepted and can be mapped via Throttle/RPM.
A wide band signal can be modified (not intercepted and not displayed!).
This feature gives the ability to modify a closed loop system on cars that already have one installed.
It is now possible to modify the closed loop system with a wideband unit to make more precise tuning for low-mid power ranges
ANA2 MAP
An analog signal is intercepted via the A2IN/A2OUT connections and mapped via Throttle/rpm, AMP and Engine temperature for the purpose of altering fuel at specific engine conditions.
A second input for Analog signal so you can modify open and closed loop using the same piggy back system or whatever else you can think of (maybe getting rid of your AFM)
More below....
IGN MAP
ANA1 MAP
OXY MAP
ANA2 MAP
More below....
