car bogs when driving cold?
Postby camry90 » Tue Aug 28, 2007 4:11 am
when i start up my car in the morning, let it iddle for 1 min and then slowly driving it down my street and it lack of power, act like boost lag, bogging severely....but as soon as the temp. gauge is at normal temp, it's alright.....does your 185 do that? everything is stock on my car. could it be 02 sensor that is still cold?
camry90
Postby GT4RC » Tue Aug 28, 2007 4:23 am
Mine does too.
GT4RC
Postby ST185pinjo » Tue Aug 28, 2007 11:52 am
I think your O2 sensor is getting bad, and needs replacing.
You can check it at the diagnostic(?) box.
ST185pinjo
Postby RedCelicaTRD » Tue Aug 28, 2007 1:57 pm
Pretty much every 3sgte does that.
Postby camry90 » Tue Aug 28, 2007 5:58 pm
ST185pinjo wrote:I think your O2 sensor is getting bad, and needs replacing.
i never get any engine code
camry90
Postby GT4RC » Tue Aug 28, 2007 11:21 pm
me either. This winter i want to replace all my oem vacuum lines with silicone, as well as plugs and wires. distributor was replaced when i got it.
Then I'll go from there if it still does it..
GT4RC
Postby ST185pinjo » Wed Aug 29, 2007 12:35 pm
Is this only just, or always?(maybe I misunderstood the question) It is true that the ST185 doesn't like to wake up and go, it needs a warmup. With the new SM4 it is much better. May be the cold O2 sensor.
ST185pinjo
Postby camry90 » Thu Aug 30, 2007 4:42 am
every single time... so what i do i let it warm up for 1-2 mins then drive it gently
camry90
Postby muneo » Sat Sep 01, 2007 3:57 pm
I have a few leads to this morning boggin issue...
-The water temp sensors on the block maybe malfunctioning or the wires to it might be loose. When I fixed this problem, the bogging went away...for a while...
-The problem seems to get worse the more mileage I put on my oil and it tends to go away after a fresh oil change
-The problem gets worse if your low on oil.
-Cold start injector might not be working properly if at all. Maybe the water temp sensor has something to do with this?
-Check you distributor cap for oil. Oil could be building up overnight on the lowest contact and messing with the spark. You need to replace the distributor shaft seals.
Thats all I got for now. Try addressign these things and let me know if they solve your problem....
Ex-185 Owner
muneo
Postby lagos » Sat Sep 01, 2007 5:38 pm
i had to deal with this issue for a long time, until i finally figured it out. when this hesitation happens, your car is actually not getting enough fuel, and gets dangerously lean. if you have a wideband, you can see this in action.
the problem is with the 17yr old afm that most of us have on these cars.
sometimes, you can help fix the issue, by playing around with the idle adjustment screw on the afm. but this is just a work around for a faulty unit. the only real way to fix it would be to replace the afm with a brand new one. if you buy a used one, it will probably have the same issue.
lagos
Postby sims » Wed Sep 12, 2007 3:01 am
I was under the impression this was a common issue of the 3SGTE? anyone I know with one reports the same thing.
sims
Postby Tazka » Wed Sep 12, 2007 7:09 am
I have the same thing on mine.
Tazka
Postby Rick89GTS » Wed Sep 12, 2007 7:16 am
sims wrote:I was under the impression this was a common issue of the 3SGTE? anyone I know with one reports the same thing.
Same issue with my '88 ST165.
I know of one fellow who put the 89 ECU into his 88 AllTrac and he thought it performed better. Supposedly Toyota modified the 89 ECU to alleviate this problem. But if this was the case, wouldn't the 90-93s be free of that problem?
Link:
http://alltrac.net/phpBB2/viewtopic.php ... highlight=
Rick89GTS
Postby etantshi » Wed Sep 12, 2007 8:33 am
Link:
Maybe, but the AFM/ECU "relationship" is different on the st165 compared to the st185. Since it was designed differently, it is possible that they thought they had redesigned the problem into oblivion when in fact it may not be the case.
André B.
1991 ST185 (down but not out)
1996 RZN140 (the daily)
etantshi
Resolution to this problem??
Postby 3sgte4me » Fri May 08, 2009 3:54 am
Anyone got a clean resolution to this issue?
My house, my wife, even my right nut can disappear, but never again will I give up my Alltrac.
3sgte4me
