st165 maf sensor
st165 maf sensor
Postby 903SGTE » Fri Nov 05, 2004 10:14 am
can i use an st165 maf sensor on my st185??are part #'s the same?
903SGTE
Postby Gary » Fri Nov 05, 2004 10:15 am
If I'm not wrong, no, they are different.
93 ST185
Gary
Postby alltrac.net » Sat Nov 06, 2004 3:22 am
They are technically different, different part numbers and all. However, I have swapped them without a problem. The difference, if any, should be slight.
You can do testing on the AFMs to compare, but in a pinch you CAN swap them to get you on the road.
You can also use an MR2 AFM and a 88 RX7 AFM.
ST165, then ST165, then ST185, then ST165.
Yes I've been there.
alltrac.net
Site Admin
Postby Austen_gt4 » Sat Nov 06, 2004 4:10 am
i have one for a 165 if u need one. Austen_gt4@yahoo.com
2006-DURAMAX RaPeVaN
2008-RUCKUS
2004-IS300
1993-MR2T X 2
1992-GT4
1991-SPEC MIATA
LOTUS 7 (in progress)
Austen_gt4
Postby 903SGTE » Sat Nov 06, 2004 11:54 am
does anyone have a good st185 maf.mine is on its way out.it ahs 200k onit and when i decel in gear the car bucks.when i cleaned out the maf with throttle body cleaner it ran fine.only lasted about a week.
903SGTE
