RWDragoon":2e05n6tv said:Just tuned a supra with a SM4 tonight stock engine VVTi with GT35R turbo and 830cc injectors (full race fuel pump) and on pump gas at 19lbs of boost made 430hp and 384lb/ft of torque not bad for a full street setup
RWDragoon":133kr6if said:we are at like 3000ft above sea level. Running 91 octane pump gas 430hp is a good number up here. It is a conservative tune with about 11-11.2air/fuel. With race gas we could do high 500's maybe 600. The biggest problems we have with the SM4 is VVT-i Cam control.. Its very difficult to find information on.
Simba":y8lyjym7 said:Any of them will do it, it depends what you want out of the system. If you want to plug it in and go (more or less), AEM. If you want better anti-lag abilities and the ability to self-tune it on the road, check out Autronic.
If you're going to be running lots of boost and want maximum flexibility over your timing and fuel maps, pay a few bucks more and go MoTeC.
I'd stay away from the hobbyist systems like the MegaBoom, they don't have enough map points for a properly running street engine IMO.
Hic":jzn3n8tx said:first of all, go to MS forum and see the problems yourself.
Then you can decide
silence":1v4bxsns said:Hic":1v4bxsns said:first of all, go to MS forum and see the problems yourself.
Then you can decide
I disagree. MS is a great tool for those that know how to tune and want total control without breaking the bank. I'm currently installing it on my turbo bmw. Dont be so quick to dismiss it, there is great support, and a lot of options when using it.
purplecelicaGt4":1gwbrs40 said:oh goodness.... Why no one giving no reasons??
Hic":1s7d2ctr said:I know how to tune and precisely because of that I know MS CAN'T DELIVER!
