Apexi fc
Apexi fc
Postby tas_gt4 » Wed Nov 10, 2004 11:43 am
Hey all,
Thinking about getting the apexi fc, with the hand controller....just wondering if anyone has anything to say about these units...good or bad. A friend has one installed in his st205 and says its fantastic, just pull out your old ecu and plug in the apexi...so im thinking, sounds good along with all the other good things it sounds like it does. So just after some input from anyone.
BTW- this is my first post as registered user just want 2 say hi 2 all and say i love this site (forums) ...makes the world a better place :)
I am in constant thought (dreaming) of more power.
tas_gt4
Postby tas_gt4 » Thu Nov 11, 2004 9:39 am
its ok all..just found out that i cant use the apexi fc in my st185...apexi only do for st205 :( not happy....any other ideas guys on a good cheap plug n play engine managment system for a 90 st185
tas_gt4
Postby Mark0 » Thu Nov 11, 2004 9:51 pm
AFR
4g63=the replacment for displacment
Mark0
Postby tas_gt4 » Sat Nov 13, 2004 7:11 am
what is AFR?
tas_gt4
Postby Gary » Sat Nov 13, 2004 7:39 am
93 ST185
Gary
Postby saved_1992 » Sat Nov 13, 2004 1:53 pm
dont they make one for a mr2? i thought the mr2 had the same ecu as the 185 (depends on the year)
mike
omaha,ne
1988 a driver (RED) sold
1992 the keeper (RED)
1993 sold to 2of81 (RED)
saved_1992
power fc
Postby sardgt4 » Sat Nov 13, 2004 8:31 pm
You can use a power fc on the st185. It just requires some minor rewiring. Also you will have to add an air intake temp sensor pre throttle body and change the ignitor to a st205 ignitor. Fairly simple. I have a 3rd gen mr2 ecu in my st185. I therefore ditched the air flow meter. I did this all with the intent to buy a power fc in the future. The power fc is only $850 shipped now with the commander which I think is a great deal. Hope this helps.
John 92 st185
sardgt4
Postby Terboman » Tue Nov 16, 2004 6:13 pm
True, the normal Power FC is only for 3rd Gen motors. However, AP Engineering make a Power FC for 2nd Gens.
http://www.ap-engineering.co.jp/
Good Luck.
Lee
2 Alltracs down...none to go.
Yes....I own a G35 now. :D
Terboman
