SMT-6 installed!
SMT-6 installed!
Postby ChrisD » Sun Nov 14, 2004 12:20 am
Hey guys,
I've now finished up the install of my Perfect Power SMT-6. As described in one of the other threads in this section, it is a piggyback computer that gives me full control over fuel and ignition timing, plus allows for extra injectors, as well as a lot of other things. Check it out here: http://www.sea2skytuning.com ..."Weasy2k" on this board is the owner of that site and was extremely helpful to me during the installation.
The install went fairly smoothly, except for my battery which needed to be boosted. Other than that, it starts and runs beautifully. I'm using this in conjunction with a J&S Safeguard.
I can't really do much for tuning until I get a wideband o2 sensor, which I will be getting from the group buy sometime soon.
Here is a basic wiring diagram on how to install the unit: http://www.snimoc.com/pix/smt3sgte01a.jpg
The only difference between that and how I installed it is that I used the Air flow meter for the load signal, instead of the throttle position sensor.
I'll keep everyone posted as I progress with the project. I'm aiming for a ~17psi street tune, on 540cc/min injectors. The software is extremely easy to use. I might post some screen shots of it later.
Just thought you guys would be interested in this, since it is a much cheaper option than the Greddy Emanage, and is easily just as capable, possibly even more so since I'm told it is even possible to use it to remove the AFM altogether.
Chris
1988 ST165
1994 ST205 WRC
ChrisD
Postby Weasy2k » Sun Nov 14, 2004 1:27 am
Good work Chris! Its nice to see this working out for you, and no problem with the help on the install, all the confusion is finally starting to be sorted out.
Look for new updates on the Sea2Sky Tuning website with proper wiring diagrams for the MR2 and the GTFOUR (similar to chris's setup)
Good luck on your future projects Chris and keep me up to date!
-Johnny
1991 Mr2 Turbo
Sea2Sky Tuning
Perfect Power SMT6/7 Dealer
Weasy2k
Postby ChrisD » Sun Nov 14, 2004 2:10 am
Will do Johnny! I've started to play with it a bit...its cool listening to the engine responding and making some adjustments at idle. Everything is working perfect.
I've got a few screen shots now. The red cell is the current cell that the engine is in. The green cell is the one you are modifying. The 3SGTE AFM reads 5-0V, so full closed is at 100% deflection, and fully open is 0%. I found idle to be around 55-60%, ie. it is open 40-45% of the way at idle. Also disregard the A/F values, it is a narrowband and my o2 sensor is dead.
For everyone else, this program is extremely easy to use. The help is amazing. Johnny really takes the extra step to help.
1988 ST165
1994 ST205 WRC
ChrisD
Postby Austen_gt4 » Sun Nov 14, 2004 2:40 am
would/could this work with a vpc. or would it just make thing more difficult?
2006-DURAMAX RaPeVaN
2008-RUCKUS
2004-IS300
1993-MR2T X 2
1992-GT4
1991-SPEC MIATA
LOTUS 7 (in progress)
Austen_gt4
Postby Weasy2k » Sun Nov 14, 2004 2:48 am
Austen_gt4 wrote:would/could this work with a vpc. or would it just make thing more difficult?
what would you want to do with the vpc?
If you wanted to modify your fuel settings even more jsut set up the vpxc the way you want too then use the smt6 to intercept the wire going into the ECU and tune from there.
So yes it would work it would even work if you changed the injectors to something different then what the VPC is "chipped" for, as the smt6 will moify the signal like you normaly do when you upgrade your injectors.
-Johnny
1991 Mr2 Turbo
Sea2Sky Tuning
Weasy2k
Postby jhull » Sun Nov 14, 2004 1:50 pm
thats great the smt is working well. i always wondered how that would do on a 3s there was a group buy on a mr2 board, but it seems noone is responding on how they like there systems. im running a prs8. im still in the tuning process. having some difficulties, but i noticed you said you had to boost your battery... what do you mean by that. im having a problem with start up because the stock cam sensors signal is so weak so while cranking im having issues getting spark when it does spark it fires up and then runs decient. the faster the engine is moving the better the signal is coming from the cam sensor. so i mived the pickup as close as possible to the tooth and got a little better signal but still not doing it well. i was debating going with a 16v 3 post battery using 12volts for the engine and the 16v just for the starter so it cranks a little faster. but id rather not get into all that because that route will make me have to modify the alternator ect... any suggestions?
jhull
Postby Weasy2k » Sun Nov 14, 2004 5:01 pm
jhull wrote:thats great the smt is working well. i always wondered how that would do on a 3s there was a group buy on a mr2 board, but it seems noone is responding on how they like there systems. im running a prs8. im still in the tuning process. having some difficulties, but i noticed you said you had to boost your battery... what do you mean by that. im having a problem with start up because the stock cam sensors signal is so weak so while cranking im having issues getting spark when it does spark it fires up and then runs decient. the faster the engine is moving the better the signal is coming from the cam sensor. so i mived the pickup as close as possible to the tooth and got a little better signal but still not doing it well. i was debating going with a 16v 3 post battery using 12volts for the engine and the 16v just for the starter so it cranks a little faster. but id rather not get into all that because that route will make me have to modify the alternator ect... any suggestions?
Actualy i do have a suggestion (and will be sending your message to the head guys at perfect power as well so expect a reposnse via email to you)
Here is one message i got recently about the PRS unit from a PP guy:
"You see, most guys would over drive the ignition drivers of the Prs and hence would damage the unit. Hence the need for a mega spark ignition amplifier to help with running the unit"
I am unsure right now if this the case in your car but by monday/tuesday I will have answer.
As for boosting the battery....well we were wondering why it wasnt starting and about 1 hour later...we went back to our LOGICAL roots and figured...check the battery!!..yea it was dead :shrug: :)
-Johnny
1991 Mr2 Turbo
Sea2Sky Tuning
Weasy2k
Postby jhull » Sun Nov 14, 2004 7:52 pm
thanks for the help. I contacted perfect power regarding this many times. celicas been a long project. was a gt to start, then did engine swap but before i could put in the new engine i had to build it. lol
in the end I had to many modifications to ever dream of using a stock computer so i went with a prs8 then gutted most stock sensors. put in some aftermarket ones. got rid of the ignitor, mass air meter ect....
made a new harness. tested all the sensors on the bench with the prs then installed everything put the engine in and started doing more wiring then decieded it was time to fire it up. I just painted it so the car is gutted of pretty much everything. but i just wanted to be able to start it up and with some minor tuning just get it to move so i dont have to push it out of the garage all the time. thats when i ran into the issues with the stock cam sensor. crank sensor is fine got the correct rpms all the time but the cam sensor i think is to weak of a signal i sent it over to ida to have them take a look and they said it was very weak and to try to do a different set up id much rather try to get this to work, then to add more. after messing with it for some time the conclusion i came up with is cam sensor is just to weak of a signal if i take the plugs out and crank it (cranks faster) i get a pretty solid spark if the battery has a decient voltage, if i put the plugs in and crank it (around 220-230 rpms) then i dont get a solid spark it skips many revolutions when i do get spark it trys to start but most of the time doesnt. just blows black smoke.. i know i have much more tuning left but i need to get this problem under control before i can move on to the igntion and fuel map if it dont start you cant tune right. lol im going to play with a ignitor on a bench today to see if i can get it working with the prs to my knoledge it pretty much boosts the signal so if i can get it to boost the signal then i think i will be fine. once it starts it gets good spark idles well with the correct map so i think i just need to get this signal a little higher to get a solid spark during cranking. have you worked with the prs units yet?
jhull
Postby OlyST185 » Mon Nov 15, 2004 6:27 am
whats the price for that standalone?
Why dont you use MAP sensor or alpha-b instead of a restrictive AFM?
-Oly (Montreal)
3SGTE'S POWER, 4WD SUPREMACY
[img]http://olyst185.multimania.com/turbo4wd.jpg[/img]
-ST185 1990 Black. RC/CS Conv.
OlyST185
Postby Weasy2k » Mon Nov 15, 2004 7:22 am
OlyST185 wrote:whats the price for that standalone?
The price of the PRS system 1300....however the new XMS system from perfect power should be a pritty nice system as well :) going for 1400usd currently (not out yet)....
Hang tight jeremy the answer awaits :)
-Johnny
1991 Mr2 Turbo
Sea2Sky Tuning
Weasy2k
Postby jhull » Mon Nov 15, 2004 10:05 am
im using amp meter now i took the stock mass air meter out when i put the ems in
jhull
Postby Weasy2k » Mon Nov 15, 2004 11:10 am
jhull...it just occured to me....do you have ANYTHING in your maps right now? Esspecialy in your timing maps?
one of the main causes for an engine to not crank fast enought o start is timing is not set properly....let me know if you need ignition maps again (i sent you some via website)
Talk to yea soon!
-Johnny
1991 Mr2 Turbo
Sea2Sky Tuning
Weasy2k
Postby Zeus » Mon Nov 15, 2004 2:28 pm
very nice chris! damn looks like this year might be the year for someone to run 12's on the stock block hey!
Blake Brown
Zeus
Postby ChrisD » Mon Nov 15, 2004 10:20 pm
Thats what I'm hoping for! :D
A couple people have made it there already, Les in Toronto with his 205 swap, and another guy in eastern europe. But I definitely think there are going to be some very quick cars surfacing next season...I'm thinking your car will be right up there too! :smokes:
1988 ST165
1994 ST205 WRC
ChrisD
Postby jhull » Mon Nov 15, 2004 10:54 pm
yeah I have a map loaded its nothing special just to get it to fire and start its base pulse is at 15degrees, problem is spark is irradic doesnt fire every revolution only fires about 2 out of 10 revolutions like i said when it sparks alot of the times it goes to start but im cranking for 5 min before i get it to start. because the spark just isnt there.
jhull
