SMT-6 installed!
Postby ChrisD » Mon Dec 13, 2004 12:47 am
Hey Kevin,
I got it used for $250 + shipping from Weasy2k. He's a dealer for them. http://www.sea2skytuning.com (all his prices are in Canadian $)
The SMT7 allows you to get rid of the AFM too. People say you can do that with the SMT6 but it is much harder. I think Johnny (weasy2k) said there might be a group buy on the SMT7 after he gets through with testing it?
This is likely a lot easier to tune than the VPC, since you get to alter maps on a laptop instead of knobs like on the VPC. So far I'm really enjoying it. I am currently waiting on a set of o-rings for my injectors, and my wide band to arrive, then I should be ready for some real tuning. :)
I will absolutely keep people updated as I make progress! If you have any other questions Kevin just ask. :)
1988 ST165
1994 ST205 WRC
ChrisD
Postby ChrisD » Mon Dec 13, 2004 12:51 am
This is the only site I can find on using hte SMT6 to replace the AFM with a MAP. http://www.idaautomotive.com/changing_o ... ap_sen.htm
Johnny are there any other sites out there that describe this process?
1988 ST165
1994 ST205 WRC
ChrisD
Postby Weasy2k » Mon Dec 13, 2004 8:53 am
chris_dittrick wrote:This is the only site I can find on using hte SMT6 to replace the AFM with a MAP. http://www.idaautomotive.com/changing_o ... ap_sen.htm
Not that i know of chris, i just discovered that site today as well after talking to Canspeed to find out where my smt7 is :P (delayed :( )
However i was sent a email on how to do it by one of the PP techs, im going to make it into a write up as soon as i get the smt7 installed in my truck and the smt6 installed in car (testing both vehicles).
-Johnny
1991 Mr2 Turbo
Sea2Sky Tuning
Perfect Power SMT6/7 Dealer
Weasy2k
Postby pog0 » Mon Dec 13, 2004 11:01 am
Maybe I should have read, just saw a dollar sign and was like damn 710! Thank god its canadian... much more appealing.
There is a used smt6 on ebay for 250, dont know if i should do that and try to do the map sensor conversion or just save for the turbo.
Kevin Hall
92 Gray ST185 - Sold
01 GGP IS300 - Sold
06 GG Evo IX MR
San Diego
pog0
Postby Weasy2k » Mon Dec 13, 2004 4:19 pm
92AllTracTurbo wrote:Maybe I should have read, just saw a dollar sign and was like damn 710! Thank god its canadian... much more appealing.
The MAP conversion with the smt6 is not a easy job since you have to read voltage of the map sensor for each cell in the smt6 and record voltage of your AFM as well. At this pointyou will remove the AFM and plug in numbers to match your stock AFM's voltage. Then from there you will be able to tune like normal, easier said then done.
If you wait for the smt7 which is about 100-150usd more then the smt6 you will be able to have alot more features like boost control (with boost solnooid needed) and auto tune afm to map conversion :)
Yea sorrya bout the USD prices...im going to be adding them in shortly as well. There is alot that has to be added.
-Johnny
1991 Mr2 Turbo
Sea2Sky Tuning
Weasy2k
Postby pog0 » Tue Dec 14, 2004 6:41 pm
Looks like its around 600 bucks USD, then I would probably need to buy a VPC harness or something since I really dont want to splice all those wires into my harness. Good deal though, when I have extra cash, I will be picking one up myself. I gotta get rid of that damn AFM again. :shoots:
Kevin Hall
01 GGP IS300 - Sold
06 GG Evo IX MR
San Diego
pog0
Postby Weasy2k » Wed Dec 15, 2004 1:22 am
92AllTracTurbo wrote:Looks like its around 600 bucks USD, then I would probably need to buy a VPC harness or something since I really dont want to splice all those wires into my harness. Good deal though, when I have extra cash, I will be picking one up myself. I gotta get rid of that damn AFM again. :shoots:
Woud you be interested in a harness? I am in the works of getting harnesses that will plug and play into the 3s-gte ecu's. cost around 100ish usd.
The smt6 is 583usd
-Johnny
1991 Mr2 Turbo
Sea2Sky Tuning
Weasy2k
SMT6 Analog global settings
Postby 3sgte4me » Tue Dec 21, 2004 1:54 am
Hello,
Does anyone know how to set the analog global setting for fuel? It is perplexing me.
:shrug:
My house, my wife, even my right nut can disappear, but never again will I give up my Alltrac.
3sgte4me
Re: SMT6 Analog global settings
Postby Weasy2k » Tue Dec 21, 2004 3:39 am
3sgte4me wrote:Hello,
:shrug:
what in particular are you confused about?
-Johnny
1991 Mr2 Turbo
Sea2Sky Tuning
Weasy2k
How do you set the fuel settings?
Postby 3sgte4me » Tue Dec 21, 2004 4:50 am
How do you know what to set the voltages to ? ie 4.2 or 3.2 or 5 or ??
3sgte4me
Re: How do you set the fuel settings?
Postby Weasy2k » Tue Dec 21, 2004 6:03 am
3sgte4me wrote:How do you know what to set the voltages to ? ie 4.2 or 3.2 or 5 or ??
you kno wby the type of maf/afm....in our case our mafs read 0v at full fuel (so your upper fuel limit is 0 ) while your lower limit is 5v.
This is because our cars have reversed (for some reason) polarity air flow sensors.
Now what that does is make the smt6/7 NOT go above or below those set voltages because it will set a fault in your ecu if your modification takes you beyond those limits (the stock ecu does not know what 5.5v is as an example)
-Johnny
1991 Mr2 Turbo
Sea2Sky Tuning
Weasy2k
E6X
Postby Green » Wed Mar 16, 2005 10:58 pm
Jhull's problem sounds very much like the problem im having. I have a Haltech E6X and the signal does seem weak, rather than buy the MSD I bought haltechs equivilant an RA8 or reluctor adaptor, which does the same as the msd in that it converts the analogue synware to a more flat digital waveform. Theres me thinking it would solve my problems............
nope, rpm signal still fluctuates on occasion. Here is a post I made on the Haltech forum:http://p210.ezboard.com/fhaltechdiscussionforumfrm1.showMessage?topicID=1092.topic
Anyone got any suggestions?? Its difficult now as the peeps on the board are starting to slag each others products off and its not really helping my problem!
J
Christ, I haven't felt that good since Archie Gemmill scored against Holland in 1978
Green
Postby furpo » Fri Mar 18, 2005 2:01 am
chris i was ging to ask you if you have run out of afm range. i see you have.
have you managed to fix the problem yet?
roger
furpo
Postby ChrisD » Sat Mar 19, 2005 9:14 pm
furpo wrote:chris i was ging to ask you if you have run out of afm range. i see you have.
roger
Not yet. After I get my car set up and tuned with a wide band, the next step is to convert to MAP using the SMT6. This allows me a great deal of extra adjustability. Here are my very initial readings from the AFM and MAP sensor from my greddy boost gauge.
AFM signal --- MAP signal
2.8 V --- 1.0 V (idle)
___ V --- 1.9 V (0 psi)
___ V --- 2.6 V (0.5 kg/cm2)
___ V --- 2.7 V (0.6 kg/cm2)
~0 V --- 3.7 V (1.3 kg/cm2)
~0 V --- 4.6 V (2.0kg/cm2)
1988 ST165
1994 ST205 WRC
ChrisD
Update on the SMT6
Postby 3sgte4me » Sun Apr 10, 2005 6:44 am
Hey Chris,
There are probably multiple posts asksing for your advice but this one is asking for an update on the smt6 setup.
How is it going and are you happy with it or considering going with something else?
3sgte4me
