So I just replaced my head gasket and now I'm getting nothing. It cranks well, but no signs of starting... no popping or mis-timed sounds whatsoever. So either fuel or spark is non-existant.
Spark (i'm convinced this is ok)-
- Spark is in the wires, as a timing light blinks when hooked up to any 4 plug wires
- So the only possibility i see is plugs. old but worked before I began HG (and once agian there's not any sign of it starting on any cylinder)
Fuel
- Fuel pump is on when cranking, and when I jump it at service plug, sure enough, fuel lines bulges some and fuel is coming back through the fuel return line (filter and pump ok?)
- So, either fuel pressure is wrong, which I would suspect a hard start
- or the injectors aren't turned on...
the Toyota Service manual says you can listen to the injectors with a sound scope (or a screwdriver)... what do they sound like when operating normally?
Also, I don't smell fuel in the exhaust, but I have yet to get someone to crank for a while as I'm smelling.
So I'm a bit stumped... what should I check next based on probablilty of cause, and ease of checking? Fuel pressure regulator, a relay, vacumn line... I don't even know what else!?!?!? Is there anything that would cause the ECU to just not fire the injectors?
Thanks guys.
Fuel
Thanks guys.
