AEM base map
AEM base map
Postby BayAreaAT » Mon Jan 14, 2008 5:02 am
I cannot get my car to start. Can anyone please help me witht the base map . I have the 800cc sard injector,gt3076r turbo,ross intke AIT,MAP.
email me christian.mendoza@ovisomfg.com
thank you
Chris M.
91 ST185 "money sponge"
Ford Ford (Daily Grind)
R1 Yamaha ( Need for speed)
Ford F150
Chrysler 300c Hemi baby!!
BayArea,California
www.Boost2maxx.com
BayAreaAT
Postby bitter » Wed Jan 16, 2008 4:48 am
I can modify a base map and send it to you but need to know what which MAP you have. Is it the stock Toyota or an AEM or GM?
bitter
Postby BayAreaAT » Thu Jan 17, 2008 3:41 am
AEM Map 3bar and AIT sensors
Chris M.
Ford F150
BayArea,California
www.Boost2maxx.com
BayAreaAT
Postby pit_celica » Thu Jan 17, 2008 4:24 pm
Does someone of you can send me the stock AEM base map for the 3rd Gen 3SGTE (540cc injectors). I want it to compare with my megasquirt.
1991 Toyota Celica GT-S ST184 with 3SGTE gen4 ST215 swap, Megasquirt 3 + MS3X, t3/t4 turbo, 3" full exhaust, front mount intercooler and more for fun !!!!!
pit_celica
Postby bitter » Fri Jan 18, 2008 7:03 am
Pit_Celica, AEM doesn't have one for the 3nd Gen 3SGTE.
BayAreaAT, I sent you the base map. The first map I forgot to change the injector size for the fuel curve.
bitter
Postby pit_celica » Fri Jan 18, 2008 11:28 am
ok sry, I was thinking that they do. Sry again!
pit_celica
Postby evo » Fri Jan 18, 2008 3:44 pm
I'm looking for a similar startup map
stock intake
860cc inj
GM 3bar MAP, GM IAT
Cheers
1992/ST185
evo
Postby bitter » Sun Jan 20, 2008 6:45 pm
Evo,
I don't see the Injector drivers(battery offset) for the 860cc injectors in the wizared. Are you sure they are 860cc? Who makes them or what brand are the injectors. If we can't find the drivers for them then you'll need to send the two injectors to AEM to get them flow test for the battery offset.
bitter
Postby BayAreaAT » Tue Jan 22, 2008 9:33 pm
Thanks guys for all you help, I got the car to start
Chris M.
Ford F150
BayArea,California
www.Boost2maxx.com
BayAreaAT
Postby alltracshoak » Wed Jan 23, 2008 1:08 am
BayAreaAT® wrote:Thanks guys for all you help, I got the car to start
now get that thing tuned and show us what that turbo can do. :wink:
current:
90 st185
GT4 AWD
rip: 92 st185 @ 178k :(
alltracshoak
Postby donteatbugs » Fri Jan 25, 2008 3:51 am
i would like to see some hp numbers and reviews of your setup. im wanting to go with a gt3076r too. im running a hydra nemesis right now though.
donteatbugs
Re: AEM base map
Postby alltracst185 » Thu Aug 18, 2011 9:30 pm
Bringing back from the dead, I need a base/startup map for my car, I bought BayAreaAT AEM EMS. Here are my specs
HKS GT3040
RC 1200cc injectors
AEM 3.5 Bar MAP
AEM AIT
Thanks!
alltracst185
Re: AEM base map
Postby klue » Fri Aug 19, 2011 1:09 pm
Ill do a basemap to your specs
$25
Re: AEM base map
Postby alltracst185 » Fri Aug 19, 2011 7:55 pm
klue wrote:Ill do a basemap to your specs
$25
will it be good enough to drive my car to break the new engine in? PM me :D
alltracst185
