is anyone running map ecu? my car was on the dyno and under light load everything is fine, smash the throttle and it pulls extremely lean then very rich. backfires and throws dtc 31 and 34. MAF and turbo pressure sensor. then goes away. has anyone had these problems and or found a fix? any direction would be a help
