phattyduck
New member
I tried searching around a bit and couldn't find an answer to my question.
What are the differences between the two gen3 3s-gte Power FC versions? Are there any real differences?
I know that the stock MR2 ECU controls the electric power steering pump and the stock ST205 ECU runs the intercooler pump (from different ECU pins that don't interfere with each other). I assume otherwise that they are programmed the same... Worst case, I can wire my intercooler pump to run constantly, which would not be a big deal to me. I would be using it on my ST205 swapped Camry and I want to keep the stock AWIC in there.
I can pretty easily get a brand new MR2 Power FC, but the ST205 one is a different story... and yes, they are supposedly both discontinued from what I hear.
I'd appreciate any info you guys have.
