I have a few questions regarding an ECU and AFM swap, I have searched the forums and found useful information, but not all that I need.
What parts do I need for an rc ecu swap? I already have the Air flow meter and the ECU, and can get the wiring loom also, is there anything else that I need?
I saw a 205 to 185 writeup and it said something about injectors? I assume I don't need to upgrade the injectors as they are the same in the RC as the JDM.
Is there any hidden dangers of upgrading the ECU? I have a FMIC on the way, but at present I'm running the stock IC, If anyone was going to comment on chance of detonation on higher boost.
I noticed the plugs are completely different on the RC as you can see from the pictures below. Is there any rewiring needed, even if I get the harness?
I'd like it to be as plug and play as possible.
Heres a comparison of the AFMs, RC on the left and JDM on the right.
Below is the JDM AFM Plug
Below is the RC AFM Plug
