If you are thinking about calculating your actual VE, you will have to measure the actual CFM.
http://www.installuniversity.com/instal ... 012000.htm
Otherwise, you can approximate VE from engine output (HP).
VE = (HP x 792001.6) / (AP x CR x CID x RPM)
VE = Volumetric efficiency
AP = Atmospheric pressure in psi
CR = Compression ratio
CID = Cubic inch displacement
RPM = Revolutions per minute
