Megasquirt FAQ, writeup (Updated 30/10/09)
Re: Megasquirt FAQ, writeup (Updated 30/10/09)
Postby pit_celica » Sat Aug 06, 2011 3:47 pm
Hi,
I've sent you my .msq file via your email.
For the 1600 RPM thing, do a datalog and send it to me. I'll have a look!
Sam
1991 Toyota Celica GT-S ST184 with 3SGTE gen4 ST215 swap, Megasquirt 3 + MS3X, t3/t4 turbo, 3" full exhaust, front mount intercooler and more for fun !!!!!
pit_celica
Postby Dunno2480 » Wed Nov 02, 2011 6:49 pm
I have a 88 Celica Alltrac with a 93 MR2 3S-GTE engine. I also have MS2, Any help on wiring and maybe a PM would be great. Thanks for the help.
Dunno2480
Postby UtahSleeper » Wed Nov 02, 2011 8:41 pm
Have you already started on the wiring? Are you using the alltrac or MR2 harness? Or making your own?
Have you gathered the needed diagrams? And what preciously do you need help on?
UtahSleeper
Postby coyoteboy » Fri Nov 25, 2011 4:16 pm
How's everyone getting on with their ignition maps? I've tuned for leaner than stock AFR at cruise but regardless of timing I can't seem to get sensible fuel economy. My old table further up this thread works fine still but my MPG has gone from (UK) 24-27 around town on the stock ECU to ~19 regardless of anything. Running out of ideas.
coyoteboy
Postby pit_celica » Fri Nov 25, 2011 5:07 pm
If you're talking about city MPG, I would say that TPS/MAP accel enrichment is the main player. Be sure that small change in TPS/MAP do not trigger AE more than needed. About this, I'm now using the EAE and it's working fairly nice. Even with some big changes in MAP, the AFR stay flat. I highly recommend trying to use it.
Sam
pit_celica
Postby BNZ » Fri Nov 25, 2011 8:17 pm
Do you have some start values for the EAE+celica manifold,or some guidelines ?
Also do you have the stock manifold (not ported,not polished) ? Thanks
Street ST185
Rally ST165
HillClimb Renault 5 GTE
BNZ
Images: 31
Postby pit_celica » Sat Nov 26, 2011 4:50 pm
You can look at my .msq file here :
http://www.msextra.com/forums/viewtopic ... 17#p275017
Here is a very good thread about EAE :
http://www.msextra.com/forums/viewtopic ... 66#p185966
I cannot explain it better than Ken's post.
It require patience and lot of tuning via very small steps to get it done. But first, you need t0 understand the basic of how each parameter is acting. Read this page of the manual too :
http://www.msextra.com/doc/ms2extra/MS2 ... l.html#EAE
Sam
BTW, my manifold isn't ported or polished, it's a stock ST215 one.
pit_celica
Postby coyoteboy » Fri Dec 09, 2011 5:16 pm
Cheers Sam, sorry for missing this, the forum doesnt email me any more for some reason so hadn't spotted your reply, unfortunately you're running a completely different version of the MS to me - no EAE on MS1, the closest it gets is RPM based AE, which I'm using, with a fairly high trigger thresh, it doesnt trigger with fairly normal changes in cruise speed, it only triggers with stabbing the throttle.
coyoteboy
Postby pit_celica » Fri Dec 09, 2011 5:28 pm
Ha ok, I though you were on MS2.
Sam
pit_celica
Postby MWP » Sat Dec 17, 2011 1:53 am
So what are you guys doing for knock control?
It seems the J&S Safeguard is the method of choice, but it would be nice if there was a decent/reliable knock sensor package that could be integrated with a MS3.
Any ideas?
Postby coyoteboy » Sat Dec 17, 2011 11:44 am
Personally I've just tuned for the worst fuel and given a little leeway, while listening to the knock sensor with an amp, no active knock control.
coyoteboy
Postby UtahSleeper » Tue Nov 13, 2012 6:18 pm
This needs a friendly pump. Anyone using the the MSPNP on an alltrac with stock everything? Anyone try the knock board?
I ask cause I am considering try to use the MSPNP on my trac in the near future and while I have a stock harness I can hack up a little, I would like to keep costs down and just use stock ignition instead of getting COP, trigger wheel, etc.
UtahSleeper
Postby MWP » Thu Mar 21, 2013 5:37 am
Ive been re-housing my Megasquirt3 + MS3X + TinyIOx + KnockBoard + RTC into a different box.
Its almost ready to go.
Im still waiting on G sensor & Bluetooth boards to add in as well.
The MS3 re-housing schematic...
Postby scottjackson1209 » Mon Dec 15, 2014 11:16 pm
So I'm VERY new to Megasquirt but I had a question about the 24-1 crank sensor issues. I seem to remember reading something recently about the issue being fixed...is that true? I"m looking at doing a DIYPNP MS2 for my gen 3 swap and want to make sure I understand EVERYTHING before I spend my money on it. I'm not looking for anything crazy right now, I just want to tune my engine to run a bit better since it's currently running pig rich!
scottjackson1209
Postby hoys » Sat May 28, 2016 11:49 pm
Mega ultra thread resurrection!
I just got a DIYAutoTune DIYPNP running on my ST165 if anyone is interested.
hoys
