T-VIS controller
Re: T-VIS controller
Postby Rpz123isme » Wed Jun 13, 2012 4:11 pm
Better fix. Remove the tvis.
Hesperia, CA
Rpz123isme
Postby underscore » Wed Jun 13, 2012 4:19 pm
Couldn't you just use a VTEC controller? My plan is to do what the Honda guys do, open the TVIS and do a dyno pull, close the TVIS and do a dyno pull, and where the two curves cross is where I'll set it to activate.
Postby Rpz123isme » Wed Jun 13, 2012 7:09 pm
U can do that. But if u compare the tvis plate to the head ports u will see how restricted the tvis is.
Hesperia, CA
Rpz123isme
Postby UtahSleeper » Wed Jun 13, 2012 7:42 pm
Isnt there a fair amount of low end powerr loss with the tvis removed on a stockish motor?
UtahSleeper
Postby Corey » Wed Jun 13, 2012 8:12 pm
About 10 ftlbs if I correctly recall a dyno plot from MR2OC.
Corey
Images: 50
