185 ecu in a 165
185 ecu in a 165
Postby PatmanBBE » Wed Feb 11, 2009 4:31 am
Ok I have done some reading in the efi section and I believe that I can swap my 165 ecu for a gen 2 ecu from a 185 or mr2. I have found someone to make the adapter harness for me. I just wanted to double check and see if I need to do anything else to run this ecu. I got a killer deal on ebay for the ecu and the wire harness isnt a big deal either. Just want to double check. Any help would be excellent!
1988 Celica Alltrac Blue
PatmanBBE
Postby built2run » Thu Feb 12, 2009 6:30 am
yup i did!! the car will be more responsive at the least!!!! have fun :D
ST165, black: parted and gone
ST165, white: sold to friend
built2run
Postby xCH121Sx » Sat Feb 14, 2009 11:04 am
make sure its made to go in to Mr2 ecu. the mr2s pin outs are different then the 185.
i will be doing this also once i get an ecu. whatever i can find cheaper an mr2 or 185.
xCH121Sx
Postby PatmanBBE » Sat Feb 14, 2009 10:22 pm
kewl! sweet guys thanks for the info. When I get the ecu in the mail I will google its id numbers and that should tell which it is from.
PatmanBBE
Postby sbart83 » Fri Mar 27, 2009 3:30 pm
that's cool, what are other benefits by switching to 185 ecu? curious... you raise the stock fuel cut by doing this also yes?
88' St165 #7114
91' Ford E250 Econoline
check out Myspace.com/Machinegunvendetta !
sbart83
