stock 02 sensor opperating voltages
Postby theft and recovery » Tue Apr 14, 2009 3:41 am
I have just made a dump pipe to suit my turbo swap and need to put on an 02 sensor bung.
Rather than using the factory sensor i was thinking of using a lc1 as eventually i will be changing to an ecu that can handle wideband output.
What voltage range will i need to tell the sensor to send to the ecu and which of the 4 wires (of the factory 02 sensor) are used to send the signal to the ecu
Why is it hard to convince people that standing in a freezing forest for hours to see a car blast past every couple of minutes is fun? Rally a real test for cars!
theft and recovery
