no start with afm plugged in
Postby Landon » Sat May 02, 2009 5:50 am
hey guys, so came to find that the afm was causing my car not to start. it starts when its unplugged just runs really rough. when its running i plug in the afm, bam car dies. so i am not sure if the afm is bad or what. some help would be awesome. all i did when putting in the new intake was paint it and cleaned it with throttle body cleaner. so yeah, dunno if that was bad, but let me know before i have to buy a new one.
White 1995 BMW M3
Black '90 st185 Sold :(
Landon
Postby klue » Sat May 02, 2009 2:57 pm
your AFM is damaged, so its putting out a bad signal(most likely)
check your codes,
Postby Landon » Sun May 03, 2009 7:45 pm
how do i check my codes? jumping e1 and te1 don't give me anything, even just steady blinking. so i dunno. do i need a new afm? and what ones interchangable? like that i can put on to see if thats the problem?
White 1995 BMW M3
Landon
Postby Landon » Sun May 03, 2009 9:01 pm
alright guys, i got 24 and 31 on the codes. so like expected, AFM and air temp. anyways, not sure where to go with this though?
White 1995 BMW M3
Landon
Postby McKenzieJr18 » Mon May 04, 2009 12:14 am
Landon wrote:alright guys, i got 24 and 31 on the codes. so like expected, AFM and air temp. anyways, not sure where to go with this though?
get a new afm
92 alltrac 3rd gen 3s
McKenzieJr18
Postby Landon » Mon May 04, 2009 4:42 am
where would you all recommend getting a new, or working afm from?
White 1995 BMW M3
Landon
Postby cmonteiro1 » Mon May 04, 2009 1:38 pm
Put a post in the WTB thread. These are floating around. I already sold mine though. Sorry.
1991 ST185
Mods:
Aussie DP, 3in Exhaust, Wideband A/F, BayArea FMIC, HKS SSQ Blow Off Valve, Forge Waste Gate Actuator, AEM ECU, SARD 800 , Walbro Pump, ATS Fuel Rail Mod, ATS Fuel Pres. Reg. Mod., 60 trim upgraded ct26.
cmonteiro1
Postby Landon » Tue May 05, 2009 8:45 pm
oh man, i've been so excited i haven't been on here much. found out that when i pulled my adapter part of the afm off just a little bit at the beggining of my project that i torn off the three contact points inside it. why would toyota make something that comes off with two screws so easily then it breaks the whole thing? its retarded. cause its like they use it to sell parts. lol. anyways, found a guy who had one off a four runner that worked! i'm so excited cause she started right up and has been running strong. did you all know that those where compatible with our cars? kinda convinient to know.
White 1995 BMW M3
Landon
Postby klue » Wed May 06, 2009 4:07 pm
they made it that way because your not supposed to touch it.
only i have that power
muhahahha
Postby Landon » Wed May 06, 2009 11:08 pm
and why are you so special? haha. anyways, it actually looks like a pretty easy fix. so i might fix it just for kicks.
White 1995 BMW M3
Landon
