Codelink Launch Scan tool - anyone use this
Postby MixMaster » Fri May 29, 2009 8:42 pm
I picked up an OBD I Codelink Launch Scan tool for toyota. The model # is TDS 1015T
Curious if anyone has any experience using this. It checks and reads engine codes, gives a bunch of info but just wondering if anyone else uses this.
Thanks.
'93 All-Trac Red- JDM swapped
'06 BMW 325i
'08 Chevy Tahoe
MixMaster
Postby Mafix » Sat May 30, 2009 3:53 pm
scared of a paperclip and a book?
Postby MixMaster » Sat May 30, 2009 4:32 pm
Haha This thing also has an engine monitor and let's u reset any codes, etc..still learning what all it does.
Was hoping someone else used it also.
'06 BMW 325i
'08 Chevy Tahoe
MixMaster
Postby ulis_m86 » Sat May 30, 2009 5:40 pm
paperclip works for check engine lights. but a good scan tool can tell you what the sensors are showing which can be very helpful when troubleshooting. obd 1 is really quite basic so a scan tool would be nice for problems that dont throw codes
ulis_m86
Postby Mafix » Sun May 31, 2009 1:26 am
not on our cars though.
Postby ulis_m86 » Sun May 31, 2009 7:31 am
a connected a snap on code reader to my gt-s when i was in school turns out i had a bad intake temp sensor it was showing over a hundred degrees Fahrenheit. if i go off of a paperclip and i book i would of never known.
obd 1 is very basic only the most important sensors and such are covered the rest are not. i havent bought one myself cause the good ones are costly but im sure owning one would simplify repairs if you know what your looking at and know what the specs should be at.
ulis_m86
