Deleting my AFM with 205 parts
Postby TRDcelica90 » Wed Jul 01, 2009 11:28 am
What do i have to do and how hard is it to use the 205 ecu and what not to delete the AFM??
that way i can use the 540cc injectors too!! yay
1990 Toyota Celica GT-FOUR RC Now with the power of a Garrett GT30!!
1987 Toyota Celica GT-Four ST165 Rally car in the making..
Postby MrDB » Wed Jul 01, 2009 1:26 pm
Not that hard TBH.
Need 205 igniter
205 map sensor
205 ecu
205 temp sensor / but i beleive you can take the one out of your AFM and use that.
with the ECU i would recommend getting the MR2 version if possible that way you dont have isues with removing error codes for the the lack of chargecooler.
Its just a case then of moving wires around..
Only problem is the VE of the 185 engine is totally different to a 205 one ( cams etc ) so You maybe running rich / lean... Most people only convert to 205 ecu so they can run PowerFC or similar so they can then alter to fit engine..
Car Build : [ ]
